Question about Mitsubishi VS-50607 50" Rear Projection Television
T.v. shuts off, code 24
T.v. shuts off by itself, I get a code 24, what is it?
  • 22 Answers
The safety circuitry of the TV will shut it down when it detects a problem with the TV. The code is a starting point for a tech to start looking for the problem. The 24 code is an indication of vertical deflection failure. Mitsubishi is known for not having parts for their TV sets after they get to be 6 or 7 years old. They also make consumer repair of their TV sets difficult since they will not sell their parts to anyone but a registered repair facility. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. Heat is the number one enemy of electronics, and these sets operate hot. This model of TV has over 3,000 parts which include millions of transistors inside the integrated curcuits. Over time the capacitors will change value, leak and become defective. Resistors will change value and burn. This will cause other components to become defective. This can has a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. I expect the parts needed will cost less than $50 dollars unless it needs a board replaced. Most shops will charge about $350 to repair the set if they can get the needed parts. Small TV repair shops will often charge less than a large repair facility.
Posted on May 09, 2009
FDB4315LFC2 ERROR
Hello - Typically the "ER" code displayed on your unit does typically indicate a shorted out control panel. This can happen by excess moisture getting into the control area. Let the unit dry for 24 hours with no use, and see if the display error code erases itself. If it does not, this unit will require the repair of a professional to move forward accurately.
Oct 25, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
WHAT DOES THIS CODE MEAN ON A subaru IMPREZA WRX STI : 24 open/short IN ISC VV CIRCUIT
The ISC is idle speed control its either the circuit,or the the ISC (idle speed control ) motor itself that has gone bad This is code 24
Feb 14, 2012 | 1999 Subaru Impreza
Pentair minimax e05
Try changing the "stack flu sensor". It could be the sensor is bad or the sensor could be detecting a bigger problem. The sensor can not be jumped out.
Apr 04, 2017 | Pentair Minimax NT Heater
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
Model WS55819: Shut off by itself. Power ON with remote, Green light next to power button on TV flashes twice fir 10 cycles and shuts off. Unplugged TV for 30 minutes and for 4+ hours. Same results.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
you will have to count the blinks, then there is a short pause and then following a second set of blinks this tells what is wrong with set.
Mar 07, 2011 | Mitsubishi Televison & Video
Error code: "Ih" on GE Triton XL. What is reset combo?
After leaving the dishwasher locked with the error code still showing, I returned to find that it had reset itself and run through the full cycle.
Problem solved itself.
Dec 11, 2008 | GE 24 in. GSD4320Z Built-in Dishwasher
WT-46809 will not stay on
Good Day, dimen;
This looks great. Check this out;
SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Asko 1585 wash cycle goes continuously until manually shut off
it may be a heating problem,does it get hot at all, or over heat.may be a thermistor fault.remove the door skin and see if rinse aid has leaked onto the wiring.or the board itself cauld be faulty,but are very expensive.hope this helps.
Mar 22, 2008 | Asko 24 in. 1585 Built-in Dishwasher
TV turns off by itself
you have a bad CRT causing the set to shut down. after the CRT has cooled down the computer finds all value to be ok then comes back on....
Jan 07, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Mitsubishi VS-50607 50" Rear Projection Television Logo
280 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
