Question about HP iPAQ hw6515 Pocket PC
Red Light My phone was fine the other day, now suddenly I cannot charge it in the cradle, i cannot charge it from the wall, all I get is the red light at the top. I really don't think the battery is bad. It won't come on at all.
  • 490 Answers
Try to charge ur phone on other cradle if its getting charged then problem with the cradle or else try another battery in ur phone or contact service centre for more support good luck
Posted on Oct 20, 2007
SOURCE:
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
If it is new, send it back, but make sure you carefully read the instructions first. If is says the indicator light is red on charging and green when fully charged and it doesn't do that then the batteries or the charger are defective.
In future make and model are useful. And you posted to electric drills, but I recategorised it.
Jul 02, 2017 | Audio Players & Recorders
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
I have a logitech cordless mouse that does not charge when placed
either ur cradle or ur battery hav been damaged...
try changin it...
Mar 11, 2010 | Computers & Internet
Battery in cradle don't charge
Two reasons. Either the battery is dead or the cradel's charging circuit is faulty. But the red light shows that the cradle is fine. SO, the axe falls on the battery.
Sep 19, 2009 | Casio Exilim EX-S880 Digital Camera
Plugged my cordless GE phone into phone jack "A"
You dont owe me anything dear.
If your phone is working properly. Charging, incoming call and outbound are ok then you are safe.
Blinking light is called heart beat. It tells you that system is working. Let us know if you need something else
Have a great evening.
Vit
Jun 21, 2009 | GE 27998GE6 Cordless Phone
Red Light
get it serviced,?
they are obsolete now, so finding good service is both hard to find and expensive,. it has no street value, and $- dead
the battery is no good, inside, like all are now....
Nov 03, 2017 | HP iPAQ hw6925 Smartphone
Not Charging
Same thing happened to me the other day. For some unknown reason my wep500 seemed to just die with no apparent cause or reason. So I took the unit apart and tested the battery with a multi meter. It read 3.9V. So power was not the issue, I then put it back together and by chance, happened to continue pressing the power button for 5 seconds in hope I would see the LEDs flash but no dice. Then for no reason, I went to my phone and tried to pair and to my amazement it actually paired (meaning the device must of been on). So I then hit the big button on the wep500 and sure enough it calls the last number stored in my phone. It turns out (out of all things) the led itself went bad for some unknown reason. I suggest you try charging it (you won't see the red led), try turning it on (you won't see the blue led) and then try pairing from your phone. If you phone indicates it paired, then try calling the last number from your wep500. If it works, then you too have a bad LED (I have never seen an LED go bad before). Hope this helps.
Sep 13, 2008 | Samsung WEP500 Wireless Headset
Battery charging
i have not used my camera since June, when i went to charge the battery the other night the Red light just kept flashing even after leaving it for 8 hours, i can get pictures from it which are stored in it but the shutter will not open whilist in and out of the cradle.
May 28, 2008 | Casio Exilim EX-S880 Digital Camera
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
381 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
