Question about Samsung SGH-D900 Cellular Phone
Phone wont switch on have cleaned sim battery etc but nothing. when i plug in charger keypad lights up but that is all.......help!!
  • 151 Answers
The ribbon cable from keypad to screen is probably damaged (common problem) - get it replaced.
Posted on May 12, 2009
Hanged and off
Try pulling the battery out and put it in carefully, make sure everything is lined up right. If that doesn't work, try plugging in the charger and leave it for an hour.
Apr 19, 2014 | Nokia 3110 Cellular Phone
Wont turn on
Phone will still boot without a SIM card usually just comes up and says that you need a SIM card to operate the phone but it will still boot/charge without it. Could be bad battery most HTC phones will not boot without a operational battery. Pull the battery and plug it into a charger if the Charging light goes on for like 3-5 sec. then off most likely battery is faulty if no light at all, could be a bunch of different reasons.
Nov 23, 2013 | HTC Pc36100
A friend gave me her old model 1650, new sim card, transferred into my name, all good for 4 days, now it won't do anything. Battery icon comes on when I plug into charger and keypad lights up for about 10...
If it was me i`d find a helpful network shop(and on your new network) as I presume your not under warranty.
Explain the situation to them , ask them to try a battery.
if itsnot the battery try the charger.
If its neither then its the phone.
I hope they can diagnose it before it gets to the phone bit.
Hope it helps!
Dec 29, 2009 | Lands Phones
I have a sony ericcson W380i and it now will only light up when I switch on and then nothing else happens - so the battery is OK but no function is working. It was fine last night but not when I went to...
Hi.
That means that the phone is not comleting the initial phone test, and not booting.
Remove also memory card.
Check the connector at the base of the phone, where you plug in the charger. Ensure that it is clean , and that there is nothing that can make contact in there (eg. oxide). If you need to clean the connector, remove the battery first.
Try holding the phone start button on top for about ten seconds.
Go to a shop and ask them to test a spare battery, or if you have a spare battery, test it. A shorted battery can cause the phone not starting.
If it is none of the above, then it is a faulty board. Also a short inside the phone or a faulty switch can cause the phone not starting. In that case the phone must be disassembled and repaired.
Regards.
Oct 23, 2009 | Ericsson Lands Phones
Charging phone it went off wont come back on
Remove the battery and clean the contact points. Also plug in the charger and try to switch your phone on. Also notice if the normal charging logo/picture is appearing or not. If the phone does not come ON while plugged in with the charger, then its a problem of the phone. However after cleaning the battery, put it back and try to switch ON without/with the charger and let us know the results............sodeep
May 03, 2009 | LG enV VX9900 Cellular Phone
I need unlocking lg u890
i had a lg u890 mobile phone that i got unlocked but it had the same proble where i swithched on my phone it used to ask for the usim code..my old phone was locked to the 3 nt/wrk i got it unlocked so i could use my 3 nt/wrk sim card or any network simcard but i used vodafone 3g sim card.the code i used with my vodafone 3g network simcard in phone when switched phone on & it asked for usim sim code i inserted code i got & it shut the phone down then on again then it wld work with vodafone no bother at all it even came up with vodafone uk etc.but i had to reconfigure the sms/text telephone number aswell as reconfigure the mms settings & numbers etc aswell as reconfigure wap settings from 3g network to vodaphones.but after i got it all unlocked & settings changed etc & inserted a different 3g network simcard ie vodaphone/orange/o2/3g sim/t-mobile/tesco sim/virgin sims & switched phone on it asked for usim code i tryed the code i have & inserted the same code i have it/they switched phone off & then back on & all network usim card worked with no problems at all.the code i have is.>>> 142358#*# thats 142358# * # all 1 item/action.once you insert that 142358#*# thats it your phone will shut down then restart up & go onto the network usim card you want to use or inserted before using code.but 1 thing tho please remember if u switch off your phone or your phone switches off as batterys run out no power u will need to insert the code again.& another thing code wont work if your phone switches off or you switch it off & plug your mobile battery charger into phone to charge your battery up on the phone & you switch you phone back on when you are charging your phone as the phone will switch on & say insert usim code if you enter the code the phone will switch off & back on again but it will still request usim code.so you will have to wait unto there is plenty of charge in the battery to take phone off charge & swithch your phone on get the usim code message insert code above phone will switch off & straight back on again & then it will go onto your prefured usim card then you can plug your charger into phone again to charge phone up.you can use your phone on charger when u have entered usim code & it switched off & on again & registered with the prefered network.i hope this is of use to you as it is to me.if you try this code & either if it works or not please can you let me knows ty.email watsonwhizzy2001@yahoo.com
Oct 07, 2008 | LG enV VX9900 Cellular Phone
Power problem, maybe software fault.
replaced the battery with a new one or lash the erom file
May 15, 2008 | Sony Ericsson K800i Cellular Phone
LG PRADA WONT TURN ON
I'm having the exact problem. I've took the battery, SD card, and SIMS card out and put it back in many times but nothing works. It freezes at the PRADA logo! Help!
Dec 17, 2007 | LG Prada KE850 Cellular Phone
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
Wont Switch on
ok you can get the phone service general cleaning or you can change the battery new one it should work
Oct 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
97 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
