Question about Cycling
Fitted new battery but trip meter is way out.
Fitted new battery but now needs re-callerbrating. how to do that?
    Problem Solver:
  • 7 Answers
Buy a new one
Posted on May 11, 2009
Trip Meter not working.
Odometer and Trip Meter Stopped Working - AcuraZine Community
acurazine.com/forums/.../odometer-trip-meter-stopped-working-757772/
Dec 29, 2009 - The tech said he has seen the odometer & trip meter not workingbeing ... I have a 1997 TL and the same exact thing happened to me today. speedometer,trip and odometer not working
Aug 5, 2012
Cannot reset Trip A or Trip B on New 2012 MDX
Aug 1, 2012
Trip meter resets itself
Jul 25, 2012
Trip Computer Reset feature (with refuel) question..
Dec 19, 2009
More results from acurazine.com
Acura TL odometer trip meter not working Questions ... - Fixya
www.fixya.com/tags/odometer_trip_meter_not_working/cars/acura/tl
Dec 15, 2015 | 1997 Acura TL Series
2002 honda cr v select/reset button broken
replace it, its bad.
( as speedo shop can fix it at 2 times new. ?)
Jan 21, 2014 | 2002 Honda CR-V
Trip computer
Sorry they all tied in with the radio ,do you use the trip meter ? i dont think so if your like me ,come to that i dont even use the radio ,i like to listen to the car when i driving as if anything is going to go wrong i can by the sound
Nov 30, 2013 | Cars & Trucks
When I removed my car's battery (in 2 occasions of positive first and also negative first), odometer, fuel meter, temp. meter, trip meter and all other instrument indications got reset. Even after...
normal ,if you disconnect the battery it will lose all the readings as no battery is used on the back of the dash unit .Now if your losing readings without disconnectiing the battery then you may need a new speedo head ,expensive just ignore it who needs to know what the trip meter read anyway
Oct 11, 2013 | Mazda Cars & Trucks
Since a new meter was fitted my lights keep tripping
1) Understand electric service:
http://waterheatertimer.org/See-inside-main-breaker-box.html
2) Do a heat test on breakers and outlets and switches, than a stress test on main breaker box.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
3) Check that wire size and breaker size match
http://waterheatertimer.org/Color-codewire.html
4) Break new meter with hammer and they will replace with another new meter made in China, intended to put local workers out of a job, so we can pay for automated meter reading requiring software owned by foreign investors charging at least 25 cents per month per customer to read the meter, using workers located somewhere else, which doesn't include cost of necessary towers and maintenance, or include software upgrades, or include needed security upgrades. Oh, but you will be able to pay additional monthly fee to get static snapshots of power usage at 15 minute intervals, and the switch controlling your power will be located somewhere besides your town.
Dec 02, 2012 | Electrical Supplies
Trip breaker,reset it but no power to anything. what is problem?
Probably just a fuse somewhere. Does your battery meter work? If not, there may be a fuse on the battery harness thats blown. Failing that, depending on what make of control box is fitted to your scooter, it could be a fuse within this that has blown.
Mar 15, 2010 | Shoprider Sunrunner 4 - 4 Wheel Scooter
Battery light still on after new battery and alternator fitted
Use a volt meter and make sure the battery has 11 volts or better. If not the battery does need replacing. Anything under 11 volts tells you the battery is no good to use any longer and will not hold a charge
Feb 13, 2010 | 1998 Ford Escort
I have just fitted new battery to my pride sonic but will only move very slowly even at maximum speed adjustment
Hi. Did you fit one battery or two new ones. It never pays to fit only one battery.
Have you checked for a high/low switch, sometimes called indoor/outdoor switch.
Check motor and battery connectors.
Check motor current ( amps ) with an amp meter to see if the motor is faulty.
Check brake unit is not causing drag on the machine.
Good luck. Neil.
Feb 09, 2010 | Health & Beauty
Looking for wiring diagram for 1988 escort 1.8 tdi. need to fit cd/radio existing wiribng just on chp block..
you need a volt meter and 9v battery. earth black contact from meter & then
  1. with ign off probe wire to find a live , thats the memory feed goes to yellow on radio
  2. with ign on probe wires that the constent live goes to red on radio
  3. when lights on probe wires thats the illumination feed (if fitted to car, but not used on many new radios
  4. then get 9v battery and with remaining wires pair and connect to battery, when speaker buzz's mark pair as they are ( ie front right rear left etc ) the speaker wires from the new radio are paired by colour ( one with black stripe with is the negative of the pair)
  5. there should be a ground/earth which if you cant find just hook one to the body/chassis
Jan 03, 2010 | Car Audio & Video
Cycling Logo
65 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
