Question about Nikon D70s Body Only Digital Camera
Error CHR in D70s
I have occur an errir in my D70s Camrea for many days  the error is the screen show me CHR error and formatted to my CF card I formatted it but the problem is still same. Please give me best solution
  • 2 more comments
  • Sue H Dec 11, 2007
    tried a reset of the camera with 2 buttons on top, hard reset with button on bottom, even tried a new $94 card, nothing works, still getting CHR message and camera will not work.
  • DSC71 Feb 12, 2008
    I have tried a number of different cards and still have the same CHR error on the display. Have tried a number of cards and have tried both a soft and hard reset as well. Still nothing.
  • JodyRoth Mar 29, 2008
    I've experienced the same problem which started about 2 years ago - but intermittently. I thought it was the cards...or me...but have resolved that it's the camera. I've lost too many good shots now, so I'm looking into the D40x
  • vampie_7 Aug 22, 2008
    yes
    New Friend:
Iam used d200 camera, so chr messege disply.cf card not working and don,t
formatting in camera and card reader.whatis the solution.
Posted on Aug 13, 2012
Take the CF card out of the D70, and take a professional can of Dust Off and spray a blast of air into the slot. This will remove any dust the have inadvertently gotten into your camera.This worked for me.
Posted on Aug 05, 2009
    Champion:
  • 217 Answers
Try another cf card first. if the trouble is still the same,  there is an internal malfunction in the unit, you need pro fix then.. [:0(
Posted on Oct 11, 2007
    New Friend:
  • 28 Answers
AS AN EXPERT I WII SUGGEST TO OPEN CAMERA SEPERATE THE CF CARD SLOT THERE COULD BE DRY SOLDER ON ANY OF CONTACT PINS,OR DUST ON THE PINS OR FPC CONTACTS GOT SLIGHTLY BLACKENED AT THE POINT OF THEIR RESPECTIVE CONTACTS(DENTS).GET THEM CLEANED,REFIX& SEE YOU WILL NEVER HAVE THE PROBLEM FOREVER
Posted on Apr 11, 2008
SOURCE:
Yea so my d70s body just says CHR and it wont take picturs,, can u please help me
Take the card out blow the dust out of the card slot make sure all the pictures have been transferred to the computer then format the memory card in the camera it is to be used in.
Jan 20, 2011 | Nikon D70s Body Only Digital Camera
Nikon D 70 issue
If you lost the manual for this camera can be downloaded from Nikon directly <a href="http://www.nikonusa.com/pdf/manuals/dslr/D70S_en.pdf" target="_blank" rel="nofollow">here</a>. The error message is discussed in detail on page 200. The CHR error you're seeing has to do with the memory card. It may be a simple as: it has no more free space to record more photos, or the card may not be formatted, or is damaged. Consult the manual for more tips and worst case, try replacing the card with a new one. Format it and try again. Good luck!
May 02, 2010 | Nikon D70s Digital Camera
CHR problem Of Nikon D 70S
problem in card holder replace it
Jul 05, 2009 | Nikon D70s Body Only Digital Camera
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
Jan 30, 2009 | Nikon D70s Digital Camera
Can a SDHC card be used with a CF card adapter in Nikon D70s?
You would have to get an SDHC to CF adapter which could be pricey and they are hard to come by.
Dec 31, 2008 | Nikon D70s Digital Camera
Chr
try formatting your memory card...
Dec 02, 2008 | Nikon D70s Digital Camera
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Nikon D70s Body Only Digital Camera Logo
802 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
