Question about Panasonic Lumix DMC-FX9 Digital Camera
Camera does not stay on
When camera turned on at any setting it focus' all the way out and all the way in then the following comes up on the screen:
PLEASE TURN CAMERA  OFF AND THEN ON AGAIN
  • hyawatha Dec 25, 2007
    my camera wont stay on every time i turn it on it says" turn camera off and turn back on again" please help me with this problem! thanks
    Genius:
  • 2,985 Answers
This indicates an drive motor problem- contact customer support for your repair options
Posted on Oct 12, 2007
SOURCE:
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
My CASIO EXILIM camera wont forcus or keep the right exposure!
The focus frame does not appear on the monitor screen while following conditions.
• In the Auto mode, while the following settings are configured.
- Face Detection : ON
- Effect : Make-UP
- Auto Shutter : Detect Smile
• "MF" or "∞" selected for the focus setting.
• BEST SHOT scenes that use the above settings.
Example: "4 Portrait" BEST SHOT scene
* Changing the above settings will cause the focus frame to reappear.
If your camera wont keep the memory settigns after turn off the camera, its possible that you have some problem with the internal battery and need to be replaced.
Mar 07, 2011 | Casio EXILIM Zoom EXZ2000 Digital Camera
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
I have Nikon coolpix L110 and when there is any movement it is blurry
Unfortunately I have seen this happen on the newer models of Nikon compared to the older ones when pictures were crisp. Set the camera to a higher shutter speed , try not to use auto. If you are using auto then press down and let the focus come to stay before you click on. I think there is a delay for the focus to come on which makes it a little out of focus. So hold button midway let the green come on in the screen to pressit to click.
Your pictures will come corrrect now.
Sep 18, 2010 | Cameras
My lens focuses only intermittenly
If you have the settings on AUTO the camera will automatically adjust to what it thinks will make the best picture.
Try and use the SCN.
You can also switch the flash on and off as you wish.
For more tips and tricks on picture taking please follow this link:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=38/13915/39&pq-locale=en_US
Jan 02, 2010 | Kodak EasyShare M1033 Digital Camera
When taking pictures they are all coming out fuzzy/bleary
have a look at what the focus setting is on ,,,if its on close up's,
thats why there fuzzy, its that or the auto focus is playing up,
Nov 08, 2009 | Cameras
Infinity focus isn't working anymore
ahaha.... never mind. I was dinking around with it again and turns out, infinity focus only works if facial recognition is on... why, i don't know.
Apr 10, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
I need advice on how to take Ice-hockey action pics...
Pictures get blurred because of several reasons:
Low shutter speed - occurs in low lightning conditions.
Auto focus not focused - occurs when pressing the shutter button all the way without waiting for the auto focus ready signal (green box)
To speed up the shutter do the following:
In Camera menu-Quality- Set ISO 100 for outdoor, ISO 400 indoor.
To avert focus problems, set camera menu-Rec- Focus-Infinity, Rec-Quick shutter-On
Hope that helps.
Dec 28, 2007 | Casio Exilim EX-S500 Digital Camera
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic Lumix DMC-FX9 Digital Camera Logo
64 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
