Question about Sunbeam 4214 Iron
The microglide Sunbeam iron surface is getting dirty and it is hard to clean, how I clean it?
4 Suggested Answers
brnspncr
  • 67 Answers
SOURCE: trouble cleaning Sunbeam iron 3983
you can buy an iron cleaner from your hardware store, wallmart sell it.
Posted on Jun 11, 2009
heatman101
  • 43501 Answers
SOURCE: clean ironing face
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Posted on Jul 15, 2010
SOURCE: my wife's sunbeam microglide iron
I just took apart a Sunbeam iron. This is how it disassembles:
first remove the screw at the base. Next remove the moisture dial top (it should just pop off). This allows the iron to slide apart - the metal base from the top. It should slide about an inch then lift off.
My iron didn't get hot, and what I found is the gear that attaches the temp setting to the electrical was missing a tooth. Perhaps you could set the gear to permanently "ON". In my case I found out with brute force how the iron is supposed to disassemble... time for a new iron...
Posted on Jun 11, 2011
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
My wife's sunbeam microglide iron does not get hot. What could it be the problem?. Mauricio. Thanks.
Mar 27, 2011 | Sunbeam 4214 Iron
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
Dec 27, 2010 | Krups V70 Iron
It is dirty - how do you clean it. I think
RUB ON A BROWN PAPER BAG ON TOP OF A TOWEL ON MEDIUM TO HIGH HEAT.
Mar 17, 2010 | Sunbeam 4214 Iron
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Trouble cleaning Sunbeam iron 3983
Jun 09, 2009 | Sunbeam Best Value 3983 Iron
Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
May 29, 2009 | Sunbeam Steam Master 4055 Iron
Cleaning non stick iron surface
There is a product called goo-be-gone available at any hardware store in a small bottle which will remove the adhesive easily.
please mark this as a fixya! thanks
Mar 17, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Sunbeam 4214 Iron Logo
432 people viewed this question
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
