Condenser board gives me 6 flashes says vc ch tripped
Why does 38YDB036-310 keeps giving me 6 flashes on condenser circuit board?
  • Dennis Boxerman May 11, 2010
    What brand is this? a serial number would also help.
  • 614 Answers
When you can your cover off your control panel look on panel for Troubleshooting lights. Sometimes the board itself has the codes. Low pressure or high pressue or maybe sensor failure. Different board diferent codes.
Posted on Jun 12, 2009
The unit either encountered a brown out or a surge which burned up the board for the condenser. It had black marks on the board and the indoor unit was flashing. Replaced the board and the unit is still...
After replacing the burned condenser board, check also the entire condensing unit if still ok ( compressor and fan motor). If the light inside the indoor unit is still flashing, the timer is still not giving signal for the compressor to start. Adjust temperature and wait for 3-5 minutes. It light continue flashing, there is something wrong with the indoor unit control.
Sep 02, 2011 | Sanyo Split System Air Conditioner
Bought an upright Frigidaire Freezer on Craigslist and the inside gets cold and works like a champ but the outside side panels get very hot- is this normal or is there a short?
If there is a short circuit, the circuit breaker protection in your house wiring would trip (Open the electrical circuit path).
It is normal for the condenser, which is on the outside of the appliance to be hot because it is transfering the heat from inside the freezer cabinet to the ambient air outside the cabinet. Make sure that you give the appliance enough space all around the hot condenser so that it can transfer its heat to the surrounding air efficiently.
P.S. Some freezer designs integrate the condenser coils into the metal cabinet, thus the hot side panels.
Aug 28, 2011 | Frigidaire 14 cu. ft. / 396 liter Upright...
Goodmen 5ton ckl060 condenser breaker keeps tripping has 50amp breaker #6 wire unit runs but tripps out 5 times a day
Your condenser is either pulling too many amps and needs to be service by a tech or you have a weak breaker that needs replaced by an electrician.
Jun 16, 2011 | Goodman CKL60AR60 Air Conditioner
My LG Artcool isn't working keeps flashin ch 61
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. kHnce remove the gas, flush out the system and vacumize and then do gas charging.
Dec 10, 2010 | LG Heating & Cooling
I have an IDC75 condenser dryer. Everytime i press the start button to start drying my clothes, it will not allow me to start it and immediatley shuts off the electricity in the whole kitchen. PLEASE,...
the culprit seems to be the CONDENSER BOX. This can quickly get blocked up by soggy wet lint/fluff debris from clothes. Some clothes shed more than others, so it is best to check this frequently. What happens is that when the CONDENSER BOX gets partially blocked up, it fails to condense the steamy moist air into water efficiently, and the insides of the drier start to get damp ans steamy. Depending on the amount of moisture, and the make (Some Zanussi and Hotpoint driers may be vulnerable to this), if any vulnerable electrical part get too damp, then there will be a "flash-over" between a live component and neutral or earth (usually a part connected to the casework). This can cause the kitchen circuit breaker to trip. The fix: remove your condenser box, and give it a good spray clean in the garden with your garden hose. Any large lumps of fluff/lint that are stubborn can be pushed out from between the condenser slots with a plastic ruler. Allow to dry. Then , with power removed from the drier, use a good flashlight checking that there has not been any build-up of fluff behind the condenser box area at the rear. You may need to remove the water tank as well to see more clearly. It is worthwhile also checking the little buffer-tank at the back, where there is a level sensor switch for the water tank level. If it is full of gungy water and lint, try to give it a clean out. Give your machine an hour or 2 to dry out internally a bit before attempting to dry any clothes, in case the breaker goes again. If it DOES go again, try leaving it for linger. If it still fails after being left for 24 hours, there may be a more permanent fault, inside the top back of the dryer there should be a wiring diagram(might be on the back panel of dryer) you will need to trace wires and with multimeter try to figure out what is causing the short. Hope this helps Tim
Nov 25, 2010 | Indesit Dryers
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
York central ac keeps blowing 3amp fuse on the circuit board when the compressor kicks in. thermostat changed with no help. what's next
sounds like you have short in the low voltge side of the electrical circuit. I would check the thermostat wires outside at the condenser. look for any bare or exposed wires from where the wire comes from the house to the condenser. the thermostat wire will be a brown wire that is run on the outside which sends a signal to the contactor to make the condenser work. common cause his rodents or happens when weed whacking around condenser. Hope this get you started.
Apr 26, 2009 | Heating & Cooling
Hotpoint aquarius tdc32 condenser dryer keeps cutting/tripping out after 5 minutes usage. Press the start button immediately after and won't start. Have to give it 10 minutes or so before starts up....
It may be necessary to clean the condenser unit/module (heat exchanger). Often lint would accumulate reducing the efficiency of the condenser causing the temperature internally to rise above specs. Thermal cutoff senses and trips the unit.
In some instances, it could be the thermal sensor/thermostat. I think your particular model has two of them. To gain access inside, it would be required to remove 2~3 panelings. A continuity tester is needed to check the thermostats.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Dryers
Heating & Cooling Logo
208 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
