I tried plugging in my Ipod nano to my computer but it doesn't fit in any of the slots, what do i do?
SOURCE: my ipod nano wont do anything
umm im not sure if this will work but you could try holding menu center button untill the apple comes up (this may not work if ipod has not got any power to run)
SOURCE: I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
http://www.pchelpforanyone.blogspot.com/
SOURCE: ipod 8 gb nano froze
mine froze just before - went onto another forum, and they suggested holding down the center button and the menu button for 6 sec - and done! it restarted and it's all good again- i hope this helps someone else out!
SOURCE: ipod nano setup assistant
No Ipod nano setup assistant is popping up,
ive got all my music ready.
SOURCE: does not charge
What you may have is a low-speed USB port, when the iPod is designed to run on a hi-speed USB port All Mac computers have this and most Windows years 2005 and up have it as well. Another thing that may have happened is when you plugged in the cord, or unplugged it, you may have accidentally broke off some of the metal inside the iPod that connects to the cord Try looking at that as well. Hope this helps!!!!
And my Ipod is locked too
