Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Dishwasher timer stops at 28 min but dishwasher still run and timer does not advance
Timer minutes remaining jump backwards
The timer circuit on the main panel board has a faulty timer chip in it. It may be because of a temporary short caused by lint or dirt getting on the legs of the integrated circuit, or a crack in the circuit board.
Dec 27, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Hobart sr24h; It is doing a double cycle; runs a compleat wash and rince cycle stops then 30 sec later start over so our normal 3 min clean now takes 7 min to fully stop operating. What could be the cause...
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Sep 17, 2011 | Hobart SR24-H Built-in Dishwasher
What is the correct way to check a defrost timer on a whirlpool refrigrator to see if it is malfunctioning.
mark the timer shaft and housing and ck it 3 hr later . it goes around once every 8 hrs of comperssor run time . hint compressor does not run all the time . you can advance it untill it clicks and this is the defrost / leave it there / the heaters should come on if there ok and in 28 min it will start up the frig again . ..hope this helped // **** feed back pls ..
Jan 19, 2010 | Refrigerators
The timer on my dishwasher is really off. No
the best thing to do is replace it ... but make sure all the connectors are in place
Nov 14, 2009 | Bosch Dishwashers
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Dishwasher running on a short cycle, not cleaning
It is hard to be specific without knowing the model number of your Hotpoint dishwasher and approximately how many years old it is...
If your dishwasher has a mechanical timer knob that you turn to get the dishwasher started, I would suspect that it is failing (not advancing after a certain point.)
Please report back with what you find, OK?
Apr 20, 2009 | Hotpoint Dishwashers
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Regular cycle took 3 hours then would not shut off. Stopped at 1 min. soapy water still filled the bottom, dishes had soap on them. water finally drained almost out but I am afraid too run another cycle. ...
There is a heating element in the dishwasher that heats the water to about 155F at which point a thermostat closes and sends power to the timer to advance. If the water does not reach this temp, the dishwasher will not advance. Often the problem lies in a faulty part in the heating circuit like the heating element or the thermostat faulty but you will need a technician to verify.
http://tclaundryrepair.com/home
Feb 20, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
