Question about Dell Inspiron 1525 Notebook
Replacing keyboard, won't pop out after screws removed, how hard should i lift on old keyboard to remove it?
Trying to replace keyboard on inspiron 1525 followed the steps to the point where it said to lift the keyboard, seems to be held in place by 2 tabs near the top, how hard should i lift? i do not want to bust anything.
  • 134 Answers
How to clean the fan of my computer
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
How to clean the fan air
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
Laptop won't start after installing new keyboard
Check the screws. One of them may be too long and is shorting out the laptop. If they are all the same length, I would remove them all and try it. Then install them one at a time to find out which one makes it work or, not work.
Jul 13, 2012 | Intel Dell Inspiron 15r N5010 Laptop...
Where is the memory slot located on inspiron m5030 and where can i get instructon on how to replace it and upgrade it.
there may be one located under the keyboard...there should be screws on the bottom that have a keyboard symbol next to them..remove these to remove the keyboard and carefully lift the keyboard to avoid pulling on the ribbon cable
Mar 26, 2011 | Dell Inspiron M5030 Laptop
How to rplace CMOS cell in Dell 1564 INspiron Laptop?
turn off the laptop, remove the cables and battery. Press and hold power button for 8 secs. Remove the screws at the back of the laptop. Remove the hard drive (by flipping upwards), remove the optical drive (by removing cables and the drive itself) . Turn the laptop around and remove the screws at the top of the keyboard. Lift up the keyboard and you will see the motherboard. Then you will see a circle covered with silver coating (which is the CMOS battery). Press the eject button and insert the replacement...
Oct 09, 2010 | Computers & Internet
Keyboard on laptop doesn't work
You can do one thing before you replace the keyboard.Before you begin remove the battery the ac power.You will need to remove the Hinge Cover.You can't remove it by pulling on both sides at the same time.You will have to use a Plastic Scribe to lift one side at a time.It will pop off.There are four screws which secure the keyboard to the computer remove them,slide the keyboard towards the front to remove it.Underneath there is a ribon cable which is connected from the keyboard to the motherboard try to dislodge it without breaking or tearing the cable.Now that you have the keyboard,you can go ahead and reattach it to the motherboard.There are six tabs at the back of the keyboard that you must align in odred to replace it.Hopefully that will solve your problem.If not you will need to replace the keyboard.
Good luck
Sep 17, 2009 | Dell Inspiron 1720 Notebook
B key on my Dell Latitude popped off
Generally, once a key pops off a portable keyboard the keyboard needs to be replaced. It is pretty simple to replace and not too expensive.
Here is an example of a replacement on Ebay:
http://cgi.ebay.com/NEW-KEYBOARD-DELL-8500-500M-Latitude-D505-D600-D800_W0QQitemZ250338315590QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item250338315590&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
To replace the keyboard, just remove the hinge cover, take out the screws for the keyboard and lift the keyboard to release the cable connector.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1525 Notebook Logo
253 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
