Door will not open ...time saver light flashing
  • forsyther7 May 09, 2009
    thankyou very much hopefully i can sort it out from here
    Problem Solver:
  • 11 Answers
Usually , if there is still water in the machine the door won't open . Cause pump, filter blockage?
Posted on May 09, 2009
Clean light is flashing
As an example on a kitchenaid dishwasher when the clean light flashes 7 times this is a control error that be corrected you would press Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry with the door open and then close the door and press cancel. If your unit were a whirlpool dishwasher you can press hi temp heated dry hi temp heated dry with the door open which does end up lighting all the led's and when you shut the door makes the unit cycle into the wash stage. after you hear the unit letting water into it listen for the wash cycle to start and then press cancel. After the unit drains then you can set your unit to wash again. I will await your reply as to what type of unit you have before continueing on with a exact solution for your unit. Thanks
Rick
Oct 08, 2011 | Dishwashers
I have a kitchaid dishwasher model KUDP02FR. When I press normal wash and heated dry, then start, the green light keeps flashing and will not start. Any suggestions? I had a repair man here in August for...
There are a couple of possible ways to reset the board. Pressing the keys HEATED DRY - NORMAL - HEATED DRY - NORMAL. I forget how many times, but all the lights should come on and it will do a diagnostic cycle.
It may work with the HI TEMP SCRUB, ENERGY SAVER DRY, HI TEMP SCRUB, ENERGY SAVER DRY keys depending on the machine.
I don't remember if the door is closed or open when entering the sequence. Try both.
Mar 27, 2017 | KitchenAid 24 in. KUDP02FRSS Stainless...
Clean light flashes
First, press and hold down Cancel and see what happens. That may reset the cycle.
or
The reset sequence is :
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
If clean light flashes seven times then
http://www.youtube.com/watch?v=Hv7xOaucH7I
Check this video for detailed explanation on what is the problem and how to rectify it.
It has an video for the same.
Sep 05, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light won't stop flashing...
Some Whirlpools to reset the sequence, push Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry with the door open and then close the door and hit cancel. Push the buttons as fast as you can - within 4 seconds. Also you can try Normal then Heated Dry then Normal then Heated Dry within 5 seconds to reset. Try those and see if it resets.
You can also try turning off the breaker to the dishwasher for 30 minutes and turn back on as long as the breaker isn't supplying your refrigerator too as in some countries where several appliances can be tied to one breaker, but in the USA, the dishwasher usually has a single breaker for itself.
You can find a troubleshooting guide found inside the door panel in which the screws are taken off and the door slips off and the troubleshooting guide (or tech guide) will be found there and probably is found there with your model. For others with different Whirlpools models it is found by removing the kick plate panel at the bottom of the dishwasher and it is usually glued there. It will list troubleshooting solutions you can try for your dishwasher and diagnostic codes for your dishwasher.
The flashing light is probably an indication that something caused the cycle to not complete, whether the water isn't hot enough or a faulty motor or several things, but the troubleshooting tech guide will help address that.
Apr 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Jan 08, 2010 | Tilia FoodSaver V2240
My dishwasher clean light keeps flashing ... turned the braker off, open and closed the door several times, as well as the soap holder, moved the latch where the door closes ... not sure what else to do...
The reset sequence used was reported to be the following:
Dec 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Own a Kenmore 665 dishwasher. The clean light is flashing (7 times) and the machine won't run. Have pulled the control panel and checked the door latch switches and they appear fine. No obvious burned...
It sensed a problem in the heater circuit. try this sequence to reset the code. If it comes back again you will have to determine a cause.
Sep 13, 2009 | Kenmore Dishwashers
Kitchen aid dishwashers model kudi1o1ilbl6 won't function. Cancel light flashes 7 times pauses and flashes 7 times repeat for ever. killing the power did not reset. Advice?
open door, press in rapid sequence the following keys: hi temp scrub, energy saver dry, hi temp scrub, energy saver dry. Close the door until it latches, then open it and depress the cancel key. The lght should clear. It's a beautiful thing.
Aug 15, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
