Networking need to set up wireless access in home office
  • cwaynemc Oct 11, 2007
    I followed the instructions and the document failed to print message came up.
    Yes printer installed correctly
    Windows XP on both
    HP OfficeJet v40
Can the above steps be applied to the ML-2151N using both the UBS port and the LPT1 port?
Or must the two computers be connected to the one printer using a USB splitter type conection?
Posted on Apr 11, 2008
    Scholar:
  • 116 Answers
By that very descriptive problem....
I must assume you already have wireless networking working.
I also must assume your network is properly configured.
I also must assume your trying to print to a printer on another machine.
Right click My Computer
Click Properties
Click the Computer Name Tab
Write down the computer name
Next
On the computer with the printer, go to the control pannel, then printers and faxes.
Right click the printer you wish to share.
Click the sharing tab
Click share this printer
Now
Go to the computer that you want to use the printer on.
Click start > Run
type in \\computername and press enter (Replace computername with the computer name you found before)
Now just double click that printer, when the dialog box disappears  your ready to print.
Posted on Oct 11, 2007
  • Anonymous Oct 11, 2007
    So the printer installed successfully?
    What version of windows are you using? On each computer?
    What kind of printer is it?
  • Anonymous Oct 12, 2007
    Well first make sure you can print from the original pc.
    If that works, then delete the shared printer on the 'remote' pc, and follow the instructions again.
    After you get it connected again, try printing from Wordpad first. Then what ever program you prefer.
6ya staff
SOURCE:
Installing OKI c3400n in Windows 7 32 bit
The c3400n does not have its own wireless capability. It must be connected to a wireless print server or to some wired network that has a wireless access point (WAP) connected to it. A third option is to use a home-networking wireless router.
Individual PCs must have wireless capability also, or they can't print over wireless.
Somewhere along the line the printer must get a local network IP address, i.e. 192.168.0.102. PCs usually use Dynamic Host Configuration Protocol (DHCP) to get an IP address.
But printers are usually manually set to a 'static' IP, because static IPs don't change over time.
Usually there is a security device called a 'firewall' to protect the wired network from unwanted wireless traffic.
So, you first require some form of wireless access.
The people who require wireless printing capability must have their computers configured to make an association to the WAP. Usually requires a passkey or password, depending on the wireless security method.
A port on the firewall must be forwarded to the port used by whichever network-printing protocol is being used to communicate with the printer. There are several possible protocols.
The printer must be set to an IP address unique within the private subnet, i.e. 192.168.0.0/16, used by the local network.
PC-based network-connected devices use IP (Internet Protocol) addressing, i.e. xyz.zxy.yzx.xzy
The printer must be connected to a network switch that is in some way accessible to the WAP. Residential/SOHO (Small Office Home Office) setups use a combination switch/router device, called simply: a router.
Most of the above is done automatically, but there are some set-up tasks that require user intervention. Electronic devices know how to configure everything, after they are given proper parameters.
All you need to do is check the above items. If the printer is found by MS Windows 'searching for network printers', the hard part is done. Then you just tell Windows to use the network printer.
Jul 22, 2012 | OKI C3400n Laser Printer
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
Although my Asus once recognized my home wireless router, when Comcast sent us a new wireless router to use and a new home network was set up, my computer no longer was able to connect. I can access...
To connect to your wireless router, it needs the router's wireless settings configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2011 | ASUS Wireless (90-c1i010-00xay)
IR2200 as a printer/scanner - wireless network configuration
You need to hook an ethernet cable into your network. You could get a wireless router to extend another one and connect via ethernet into that if you prefer.
For setting up network settings, do you have the Network Guide?
Go to page 2-11 and follow the instructions there.
You can click the DHCP icon and hopefully you'll get an IP address etc. (you may have to restart using switch on right hand side of copier to turn off, wait a while then turn back on). Once you have an IP address click on the DHCP icon again to make sure it's not filled in with black and save settings.
IP address must be in same range as other devices on your network e.g 192.168.1.x or 192.168.0.x (only specify a number for x between 1 and 254, must not be used by another device). Subnet mask must be same as for other devices. It's probably 255.255.255.0 Canon Network ScanGear 2.21 (don't get the colour version) can be found on the Canon website (google it). Instructions for scanning are in the manual included with the download.
Jan 09, 2010 | Canon imageRUNNER 2200
How can i set up a connection to a network with windows vista basic
There are several ways to do this you can use a router, wireless router or set up a direct connection. With a router all you have to do is connect your modem to the router and computers to the router. For a wireless connection you need a wireless card installed in your computer and a wireless router. You connect your modem to your router and set up your wireless connection with the software that came with your card or through windows wireless service. You can also connect two computers through their ethernet port with an ethernet cord. You plug coonect them with the cord go into control panel open network connections and to the left chose set up home or small office network. You will need to configure the computer with internet access as the host and the other as a guest. You can share any type of connection such as dial up, cable, dsl, and broadband.
Dec 30, 2009 | Microsoft Windows? Vista Home Basic...
MSI VR 220 can't find wireless network at home. It can connect to the internet directly with the use of a cable. It also connects automatically to the one at the office. MSI VR 220 can't find wireless...
you can try and connect it with the cable first and access the GUI (Graphical User Interface) to configure the settings of your wireless gateway/ router. it is possible that the settings are not configured in a way your laptop would be compatible with it...
hope this helps...
Nov 28, 2009 | Computers & Internet
I trying to fix a small office network and need some help. I have a netgear ds116 hub that currently has a linksys WAP54G access point connected to it for wireless access. The access point is not encypted...
So have a hub and a wireless access point at office.
Do u have a router in the network at office ?
The default IP address of the WAP54G will be 192.168.1.245.
The Sonic firewall is a different thing.
I think you are accessing the set up interface of the sonic wall with the IP address 192.168.1.1.
Where is the access point connected ?
Is it connected to the sonic firewall ?
The access point does not have the DHCP server.
Click Here for more info about Access point
Oct 07, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Adapter and 2wire router
  1. ensure that a wireless connection is created in control panel on the pc, it may not even be attempting to connect
  2. ensure that the router wireless is turned ON, it may have been turned off as a security measure when no wireless pcs were used
  3. The security settings on the adaptor may be set to the office network and locked
    wep password at home is different or not enabled, so the secured adaptor will not connect.
make any changes from a cable connected pc (no chance of data loss)
access the routers settings page and check the settings,
then ensure the adaptor rom if present is set to the same settings
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
Connet my home pc
obviously, you cannot use a cable to link up from your office network.
1 know your provider and the kind of WAN service offered
2.Get a router that is compatible with your office network and configure your router with similar priorities with that of your officce network(a wireless radio might be require)
or if you are not vast networking,invite a network administrator to do it for u
Apr 14, 2008 | Computers & Internet
Sort out my VPN issue
On my 4350, if I go Settings -- Connections -- Tasks, there's a task "Set up a new VPN connection," which will walk me through network IDs and authentication. I worry that that isn't there in WM2003SE, but have a look. As to your second question, one serious flaw to the current communications software is that there's no way to save multiple settings sets. So when you're home or go to a public hotspot you'll likely have to empty out all your office settings, then re-input them when you're back in the office. Good luck.
Sep 11, 2005 | HP iPAQ HX2750 Pocket PC
Open Questions:
371 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
