Question about Vacuums
Replacing the roller brush
How do I remove the roller brush - there is no screw or button apparent!
  • Dave May 11, 2010
    Need a make / model number to be able to help you.
  • Anonymous Mar 16, 2014
    Need to find which screws to undo to get at brush rollers
You should be able to just pop it out. Pull one side at a time while holding the plastic housing out to the side.
Posted on Jun 06, 2010
Dyson 39-the brush does not keep turning-starts to go then quits suction apparently ok
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc39
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 15, 2016 | Dyson Vacuums
The brush roller won't spin on my dyson dc35!
roller is clogged. remove 2 or 4 screws from bottom clean rollers on each end. when replacing make sure drive belt is tight
Dec 04, 2016 | Dyson Vacuums
How do we change the roller brush
Always screws underneath. Sometimes that as in a deep socket, sometimes they are a plastic turn button.
If that doesn't help, go the manufacturer website and look under the Support option. You can also Google
make model change brush
You will end up with a video like this
Dyson DC15 Replacing Roller Brush
Nov 10, 2015 | Vacuums
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hoover mach 5 turns off after 10 minutes of use
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
Another item to check is if your dust filter is not plugged up which is located behind the removable dirt cup. This is the cup that you remove that collects the dust/dirt/hair from your floor. Take the removable dirt cup out by depressing the gold button and then look behind where the dirt cup sits for filter. This can be cleaned out by washing it with soap and water in the sink but make sure you let it dry overnight before placing it back in the machine. This probably causes some of the overheating when not enough clean air is passing through the machine.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Oct 01, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My brush will not turn, and the brush control is stuck on "off"
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Electrolux vacuum making a clicking sound when the brush is engaged
Check that there is nothing lodged between the roller brush and the main dirt channel. You may have to take off the sole plate by either locating the cross head screws underneath or if the hood pops off the top - some Electrolux models have screws now located on the top. Once the roller brush is open to your eyes, look at the drive belt and check its condition - it may be on its way out and needs replacing OR the brush roller has clogged up OR the caps which hold the roller brush in both ends of the roller are loose and need a slight tap to lock them back in.
Dont forget to rate this solution. Ty
Jul 30, 2008 | Electrolux Vacuums
Dc 14 no suction/noise
The sound you can hear is the clutch slipping the machine is designed to do this if the brush roller is jammed or foriegn object obstructing brush roller.
Remove the sole plate by turning the 3 plastic screws to unlock pull off sole plate now look for anything that is stopping brush from easily turning. If nothing obviouse but roller hard to turn by hand remove the brush roller & check the bearings at either end of the roller if they are siezed up A new roller will sort this out.
If brush roller is turning freely then your problem will be warn out clutch this will need replacing.
Its A lot to explain so try this site it has clutch removing manual for Dc14. http://dysonmanuals.llc.nu/
Jun 04, 2008 | Dyson DC14 All floors Bagless Upright...
Roller brush isn't spinning
Depending on which powerhead this is, if you removed the light cover, then removed the 2 screws, from the bottom edge, you will see a slot where you can insert a flat blade and pry out to release the tab, there is one on each side. If this one where the 2 screws are removed form the bottom, then there are 4 locking tabs, 2 on the back and one on each side.
May 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Replacing a belt on a Sebo Automatic X1 vacuum cleaner
The roller brush has stopped turning, I think it could be the belt, how do I seperate the top from the bottom?
I will await your reply.
Thankyou Val
May 18, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
118 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
