The light flashes 8 times means there is a fault with the sender the wiring or the gauge pack. Unplug the sender positive lead on the green wire bue strip black lead, it should be around 12ohms empty sould be over 100 ohms. If it reads that check your wires and if the are good it is your gauge pack.
1if u can open your tank by removing the fuel then the pipe
u just check at your tank below,there will be small electrical wire stick to a sensor and at your fuel tank once u got the fuel sensor open it there is a float with lever.open gently without damaging the float and fuel seals for the sensor
have u check the fuel sensor or float at the fuel tank
