Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
The brush is not touching the floor - the front plate is rubbing.
The brush on the Bissell steamer is not touching the floor - the front plate is rubbing.
  • khubbs1 Jun 13, 2009
    The powerbrush will not lower. As a result, the front plate drags the floor.
  • 105 Answers
Dear there is clear problem in the adjustmen of brush hair.and i see that you must have to try to b correct it..
and also i see that u must have to see that there is rubber inside it and try to see whether it is there or not.
Posted on Jun 13, 2009
    President:
  • 1,952 Answers
One of the responses mentioned the Bissell Spotlifter., being something of an expert on steam cleaning lately. As a tool, it has a very narrow opening...allegedly you have to sprary the solution out the front, and then hold the machine at a 45 degree angle to get the suction going. It's very difficult to tell if you're getting the fluid back off the carpet at that point in time, so you're left to ponder whether the stain is going up. Unfortunately, touching the area on the floor covered in whatever substance you don't want to go near, seems to be the way to evaluate if it's working. You also need to apply substantial pressure to feel as if it's working.
Add to this, the fact that carpet fibers tend to get in it, and gunk up the works. To be fair, it's really easy to pull the brush section out, but your fingers must then untangle the fibers, which are, again, covered in something disgusting you don't want on you.
The one spot where the Bissell is really helpful, is the sides of stairs. You can actually steam clean a vertical surface, which is close to impossible with any of the full size power steamers.
Bissell power steamer brushes will not turn
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller is not turning. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 25, 2016 | Bissell Power Steamer Shaft w/ Head Hose
HOW DO i FIX bISSELL pROHEAT BELT
Hi, it's Cindy from Crucial Vacuum.
Your Bissell 9200 Proheat 2x vacuum's brushroll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. Another cause could be there is debris stuck on the roller and/or bearings. To gain access to your belts, follow the steps listed below:
1. Step on the release pedal and recline the handle down.
2. Remove the Tank-In-Tank and SmartMix Tank.
3. Using a flat head screwdriver to gently pry the access door, remove belt access door located near the floor cleaning switch nearest to the handle.
4. On the bottom of the machine, use a Phillips head screwdriver to remove the red retainer plate.
5. Remove the black brush arm holding the brush in place.
6. Locate and adjust the two belts.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-steamer-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 23, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
The brush bar will not spin. The belts melt when I turn it on and the belt drive is hot to touch with smoke coming out.
The belt is rubbing the foot plate.Check to see if the foot plate is damaged.Allso check the bearings in the brush bar are free and spin without the belt on.If you cant spin the brush bar by hand with the belt not attached then your bearings are seized.Get a new brush bar
Dec 30, 2010 | Bissell Vacuums
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Momentum roller brush doesn't roll w/ pressure
This is going to sound funny, but check the wheels. Sounds like the pin or shaft that holds them is broke. Also check the tension on your belt. If the tension is to loose then the brush will have a hard time spinning.Good luck
Jul 26, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
BRUSHES NOT TURNING AND MAKES A NOISE
my brushes do not turn on my 1697-7 powersteamer pro deluxe what do i do
Nov 11, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
59 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
