Question about Panasonic DVD-RV32 DVD Player
Panasoic dvd rv32 when set television at channel 00, I get sound but no picture on a DVD. Television is 1996 rca model f25653BC
    Genius:
  • Panasonic Master
  • 1,550 Answers
See if your dvd don´t get the progresive scan sistem activated if they got it deactivate
Posted on May 09, 2009
My rca hdtv model hd52w67 has picture but no sound
The model indicated rarely has sound problems.
General things to check:
If using a cable or sat box is sound muted or turned way down?
In set menu are speakers on or off?
Some versions have a slide switch either on the back or in the menu for internal or external speakers.
Does the set have sound with a DVD etc hooked to a rear input?
If no sound only on a few channels SAP may be on either in the set or a box.
If none of these help it has a audio circuit problem.
Mar 28, 2012 | RCA HD52W59 HDTV Projection Television
Connecting dvd player to a television need a diagram t.u
If you are going to hook up the DVD player to your TV through RCA cords, see the picture below.
Hook up the yellow RCA cord at the Video-in at the back of the TV and the other end at the Video out of the DVD player to get the video.
Hook up the red RCA cord at the Audio-in(right channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Hook up the white/black RCA cord at the Audio-in(left channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Red and white/black RCA cord is for the sound.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 07, 2011 | Televison & Video
Could hear the chanels good but no pictuere
Hello
1. Check the video connection of any devices plugged into the television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
2. Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
3. Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
4. Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
5. After all the steps and it does not come on then you would need to visit a technician.
BEST OF LUCK
Dec 15, 2010 | RCA TruFlat 27F520T 27" TV
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
Program RCA F20352SF television to DVD player
I just bought the same TV second-hand and had the same problem. Solution: Use remote to change channel to 00. You can't display channel 00 using front panel - a remote is required. I have a very basic RCA universal remote, & it does the trick.
Aug 11, 2009 | RCA F20352SF TV
Panasonic dvd rv32 tv set at ch 00, play,sound only - no pic
you idealy need to use a scart lead from the dvd to the tv, then pick the "av" chanel it is plugged intoon the tv. You get a much better picture using a scart lead.
May 09, 2009 | Panasonic DVD-RV32 DVD Player
RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Feb 11, 2009 | RCA F27252GY 27" TV
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Panasonic DVD-RV32 DVD Player Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
