Question about Garden
I have a Toro GT 5 6.5 hp Tecumseh model #Lev 120 and it just quit. Checked everything. Good fire,turns over good but have a kickback while it's cranking. Everything else is working. Is there a wire somewhere that I am not seeing that goes to the kill switch?
    Problem Solver:
  • 9 Answers
Sounds like the blade hit something solid when it was running & then it had problems soon thereafter. It may have sheared the flywheel key & is not firing at about 7 degrees before (TDC) top dead center. Pull out the plug & put your thumb tightly over the spark plug hole to feel for compression as you slowly rotate the blade or pull on the starter cord. About 7 degrees before TDC is when you should get a spark. Maybe you can download a repair manual for it or have a friendly repair shop tell you when it is supposed to fire the plug.You may have to pull off the shroud over the pull cord/flywheel to see where the magnets are at TDC. I had this happen to my Lawn Boy after my grand son used the mower. A $3.00 new key solved the problem BUT it was a pain to take the top covers off. apart
Posted on May 09, 2009
6.5 toro self propel.....new plug and new gas,,,turns over but then shuts down...replaced both neoprene hoses
Carburetor Cleaning TUNE UP of Toro 6 5HP Lawnmower with Tecumseh Engine
The above link will provide a video on how to clean the carb on the 6.5 hp mower. Before you go to that length, try putting some carb cleaner in the fuel tank and see if that corrects the problem. Also, as the video shows, make sure the spark plug is getting a good spark. If the spark is weak , the fly wheel may be rusted, ot the magneto is bad.
May 09, 2014 | Garden
How much will cost a calbulator for a mower model lev120
hello, you can get a set of calbulators at harbor fraight really cheep,what are you calbulatoring on a lev 120? hope this helps,
Feb 18, 2012 | Toro Garden
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My tecumseh 5 hp engine will start but then after
Hello:
Operate the Engine Unitl it Quits and then Check for Fire to the Plug.
If No Fire, then the Ign Coil/Module Requires Replacing.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
