Question about Garden
Lawn mower died. Pull rope locked up
Running fine then froze up. Now can't pull the rope to get it started. oil level good. Nothing obstructing blade.
  • Anonymous Mar 14, 2014
    my 450 series lawn mower will not crank up.I've checked the oil level,properly primed it,and fuel level in tank is good.It still will not start up.
  • Anonymous Mar 23, 2014
    The rope is frayed and jammed
  • 82 Answers
Remove the spark plug and try to pull the rope. Sometimes the coil can get loose and wedge against the flywheel. if that's not the problem then pour a little oile in the spark plug hole, let it set a bit, if it still won't turn over then you have an internal engine problems. Not very common but it can happen
Posted on May 09, 2009
Can't pull cord to start lawn mower
Either the motor is frozen or the start assembly is jammed.
Aug 12, 2017 | Garden
Self propelled cadet mower locked up how to unlock
Check engine oil level first for proper level.If it has oil in it PULL SPARK PLUG WIRE OFF SPARK PLUG IF MORE THAN A SINGLE CYLINDER PULL ALL PLUG WIRES OFF. Put unit on its side and grab the blade and see if you can move it in either direction or if the engine is locked up.
Jun 11, 2014 | Cub Cadet Lawn Mower Deck Drive Belt...
New self propelled front wheel drive mower quit running and you can not pull start rope, it has gas & oil & spark plug is connected and we are holding blade control (gas) handle back
seized up take out plug pour oil in cylinder then hold up blade brake on it side work blade back and forth till it frees up and pull with the rope a couple of times then put plug back in then start it
Jul 30, 2013 | Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Tecumseh pull start engine on Craftsman Lawn Vac will not pull. Feels like engine is locked up.
the engine is probably not locked ! remove the plug wire, tip up and see if the blade turns. if so, try the rope again. if it wont pull, take top off mower off to investigate the pull rope problem. good-day !
Nov 07, 2011 | Garden
New mower..the starter rope is frozen, will not pull out!
look under your lawn mower as sometimes there is something obstructing the blade that keeps the rope from working. if its clear then look for something that might be obstructing the rope from pulling out
Aug 15, 2011 | Kitchen Ranges
I have a brand new (purchased this past Thursday) Troy Bilt 6.75 Self Propelled mower. I made one pass this past Saturday and then the mower started to die and the completely quit running and the pull rope...
If I was you I would already be on my way back to the store, Usually If one thing goes wrong there are more to come! Personal Opinion, did you check for oil in the mower? First though second only to twine, rope, or wires wrapped up in the blade, what ever you chose to do,
Best Wishes and Good Luck!!
Apr 11, 2011 | Garden
Turned mower on its side and changed the blade and now the pull rope is very hard to pull..its almost like the motor is locked up..I checked the shut off linkage cable,removed the spark plug, removed the...
Your piston cylinder is partially full of oil and/or gas. Take the spark plug out and pull the rope four or five times to blow everything out of the cylinder. If it's still hard to pull over with the plug out check the oil level in the crank case to see if it filled with gas while the mower was on its side. Make sure the plug is dry and clean and reinstall it. When it starts it's going to smoke a lot until it cleans out the cylinder.
Sep 15, 2010 | Poulan "Poulan" Push Mower
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
Mar 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
1,532 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
