Hold the display mode button until the hours part of the clock flashes on alarm 1. Then press the sleep button twice. This will allow you to adjust the hours part of the time using the CD forward and reverse buttons. To adjust the minutes part of the time hold the display mode button again until the hours part of the clock flashes on alarm 1 . Then press the program button once and the sleep button twice. This will now allow you to change the minutes for your clock also using the CD forward and reverse buttons. Leave for a couple of minutes and your time is now set.
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group> ---------------------------------------------------------------------- 0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute 244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn 251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up 169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
On some models, 100|AM/PM|1-- may be 100/Enter; Func|Sel may be Digicon; Level Up|R may be Control Right, Level Up/Minute or Menu Up; Level Dn|L may be Control Left, Level Dn/Hour or Menu Down; Review|Qck View may be CH Recall or Quick View; SetTime Fast may be Stereo Matrix; SetTime Slow may be Time/Day, Set Up, Clear or Menu; TV/Video/AV may be TV/AV, Video Mode, Input or A/V; Wide|TV|Loud may be Stereo Matrix, Surround or Mode; MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1 120 ENTER...........1-- 120 ENTER...........100 183 2...............2 187 3...............3 180 4...............4 184 5...............5 182 6...............6 186 7...............7 053 8...............8 057 9...............9 185 1...............A 123 A/B.............A/V 120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM 183 2...............B 187 3...............C 249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down 055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear 250 STOP............Control Left 246 PLAY............Control Right 250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left 055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up 180 4...............D 055 CHANNEL UP......Day 184 5...............E 120 ENTER...........Enter 182 6...............F 121 SHIFT STOP......Fine Tune Dwn 117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function 186 7...............G 053 8...............H 250 STOP............Hour 057 9...............I 123 A/B.............Input 181 0...............J 059 CHANNEL DOWN....K 250 STOP............Level Down 246 PLAY............Level Up 122 PROGRAM.........Menu 250 STOP............Menu Down 246 PLAY............Menu Up 246 PLAY............Minute 116 SHIFT PAUSE.....Mode 245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze 235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace 119 POWER...........Power 052 DISPLAY.........Recall 249 RECALL..........Review 248 PAUSE...........Select 122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast 122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep 116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix 116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day 056 SLEEP...........Timer 181 0...............Timer Set 056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV 123 A/B.............TV/AV 123 A/B.............Video Mode 058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up 116 SHIFT PAUSE.....Wide Hope this helps. Let me know if I can help you with anything else. JimmyC
probably you blocked dont worry unplugg it wait 2 mins and if your device has a reset switch just push it while you connect it. this most solve blocked devices....saludos
Are you connected using R,G,B (component) cables? Check them to make sure they are in firmly - if so, then try a new set - that may very well fix the rolling issue. (Unless the rolling is caused by poor antenna reception).
Press "Sleep" on the original remote control for this TV if you still have it until the TV says "Sleep OFF".
If no strong TV signal is detected, this unit goes into sleep mode, which may explain Tuner B shutting off after 5 minutes.
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
