1997 Volkswagen Golf Logo
Posted on May 09, 2009
Were is the back wiper switch located for VW polo's from 1997? mine doesnt seem to be working. Thanks. (I had to select Golf from the products gallery as Polo doesnt seem to be on the drop down menu.)
  • john Jul 31, 2012
    My wiper has no tiny button on the end?
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Sep 30, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
Helped
13596
Points
87
On the right stalk the tiny button on the end of it clicks in for the rear wiper and push the hole stalk towards the speedo and hold for rear wiper and washer.
  • john Jul 31, 2012
    I have no tiny button on the stalk
2helpful
2answers
Where is a 1997 vw polo fuel filter located ?
Hi. On the fuel tank under the rear of the car.
1helpful
How do I align the timing marks on my 1997 vw polo 14i when replacing th timing belt
bring engine to TDC no1 then use some white paint to mark gears and backplate ,then it doesnt matter where the timing marks are
1993 vw golf rear wiper doesn t work replaced wiper motor tested motor all ok when on car no good
check the fuse for the rear wiper maybe blew when replacing it if not you have a short also check the rear wiper switch make sure working correctly
1helpful
VW POLO 1.9CL Diesel 1997 wont start
hi from uk check the main lead from battery+positive to the starters solenoid is secure ? also there is a thin wire that also connects to solenoid on a terminal of its own this is the solenoid energizing wire that works starter when key start position is selected if all above is ok? then use a jump lead and connect one end to battery negative post then the other end of lead to a suitable earth point on engine ? then try starting? if it works/starts ? you have a bad earth connection to engine from battery negative lead check the earth lead connection at point on engine is clean/secure ? it usually is secured by bolt at point where engine and transmission connect ? hope this helps?
My air con ,rear wiper and fog lights have stopped working on a vw polo 2.0 hatch 2005
Consult your Car Owner manual to locate where the Fuse Box is located: Check the appropriate fuse(s) for the appliances in your car that are not working - I suspect that the AirCon, RearWiper and Fog lights are sharing the same fuse as it would be extremely unusual to have 3 separates fuses blown at the same time. ps. The Polo usually has some spare fuses in/near the Fuse Box.
Hi, need diagram of 1997 VW Polo diesel gearbox
Hi Paul, Most of these gearboxes were almost identical for vw during the those years, some manuals are available free from this site
http://carservicemanuals.blogspot.com/search/label/Volkswagen
Hope it will help you out.
Dave
CAR FAULTS
try disconecting the battery completely for about 30 minutes you may get lucky and not have blown the computer. You may also want to change the fuses anyways , sometimes they look good but are still bad.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
