Need wiring diagram
Package unit is not marked with manufacturer. I believe it is a coleman, however not sure. I need the wiring diagram for model DAYA-F042N090C. Is anyone fimiliar with this model number and know where I can get the diagram. Compressor is not starting and the diagram is faded. This is a gas package unit. Thanks for any help!
  • 116 Answers
Check the capicitor if it is domed up on top bad check the wires at the compressor to see if burnt take a insulated object and bump the contactor in to see if comp starts if so then out on low voltage circ check for call from stat on common to yellow then follow the connections may be out on low psi switch located in the suction line
Posted on May 10, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
We are replacing a coleman air condiotoner with a duo therm unit and we are not sure if the wiring is the same
some of the wires from duotherm unit not used may be for external sensors not on the coleman unit. have to look at wiring diagrams to know
Aug 20, 2015 | Coleman Heating & Cooling
Coleman wiring diagram
I can't find any manual but i found a site where the same model was installed in a 1971 mobile home. Their unit had been tampered with and is a fire hazzard.
Nov 08, 2013 | Heating & Cooling
How can I get a diagram of the wiring for Coleman A/C & Heat Unit...model DRHS042100
If you go to the coleman website for residential Air conditioners you should be able to find a diagram. If you need help with a certain part to wire I can assit you with that.
May 02, 2011 | Coleman Heating & Cooling
I have an older model Coleman Powermate 3750 Premium Plus. It is not charging. What do I need to replace?
it can be the voltage regulator that's in the control box or most likely the rectifier in the back side of the gen head it looks like a 1 inch by 1 inch by 3/8 inch black cube with 4 wire posts on it with a hole in the middle for mounting these will go bad in time and are currently avail in electronics stores even radio shack has them make a diagram and mark the wires to where they go on it and mark the rectifier as well they can be cross ref to newer ones as well their just a couple bucks get a spare to have do to a older machine this part is not in the catalog of the manufacture and un avail from them yet they are other places hope this helps
Aug 29, 2010 | Coleman Powermate Premium Plus 6250W...
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
Need wiring diagram for 1980's 3 ton package unit
I assume you know if this is correct voltage and single or 3 phase, and whether it will fit your application or not, how is the duct work going to attach, how many people will be in the conditioned area, what is the building made of, how much insulation is has...
A little more to it than just "turn it on".
If you get the models and serial and can contact the manufacturer or their representative you might get a wire diagram. Most any package unit would do. As long as you keep the original equipment controls. If you "patch" it up it may be hazardous by not having safety's where it was designed for. Or for instance It may have a anti freeze thermostat. By passing this could lead to coil freeze up and compressor damage. Leaving out a pressure switch (if any) may do the same or could become dangerous to people in the event of fan motor failure. A low temperature fan speed switch may not be needed now unless you plan to run the AC in below 55'f.
And a few dozen other factors that might need to be considered.
If you feel confident after this then contact carrier.
Please rate me as high as you can and thanks for using fixya.
May 19, 2009 | Carrier Heating & Cooling
Wiring Diagram Coleman Electra Heat Mach EL
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
Mar 29, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
346 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
