Question about Whirlpool ES5FHAXS Side by Side Refrigerator
Can you take water supply to american fridge freezer from cold water supply to washing machine? model no whirlpool 20RID4
  • Mark Nichols May 11, 2010
    you are wanting to know if you can take the line off the fridge and hook it up to your washer?
  • 909 Answers
You can buy a "y" piece that will connect to the washing machine's supply then connect both to that. They are both the same size fitting threads.
I hope this helps
Posted on May 09, 2009
  • Paul Hutchinson May 09, 2009
    you can buy a "y" piece that will connect to the washing machine's supply then connect both to that. They are both the same size fitting threads.
    I hope this helps
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold wash
Hi if this intended to be used in a commercial environment then it will need to be hot and cold water supplied as commercial machines do not have heaters! I can tell you for sure if you give me the exact model number..
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine
If it is a hot and cold fill m/c, then you can just use it from cold water.
You would need to fit what is called a Y piece connector , this supplys water to both hot and cold valves regardless of what prog you select..
You connect the cold supply to the straight leg of the connector, and the hot and cold to the other 2 connections.
Plz rate this solution.
Thanks.
Whirlpool ES5FHAXS Side by Side Refrigerator Logo
122 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
