My vehicle wouldn't start (assume distributor)then I accidentally broke a piece of the engine bloke, a specialized welder is going to repair it for me.now i need to take the engine apart, don't have money to hire a mechanic, need help with timing belt, and complicated things like timing on distributor... and general advice..I have little mechanical experience.i have not started dis-assembling it yet.
SOURCE: 2000 Honda Accord Headlight Assembly
what i suggest i can suggest is, buy a clear sealant, and seal the sides of the headlights.
the reason why is air can creep in tha lamps that's why it gets moisture (foggy) and dirty.
hope it helps.
SOURCE: Timing Belt Broke. 2002 Volkswagen Passat . Time for a new car?
i would go with the mechanics advice and allow them to fix it. 1200 to 1500 beats spending 4000 on another motor if that one can be saved
SOURCE: Timing Belt broke while driving my 96 Toyota Rav4,
Zero tolerance means the valves may have hit the piston when the timing belt broke. I would suggest doing a cylinder leakage test to see if the valves are bent or not. If the valves are not bent then you can replace the belt and everything will be ok. If there are bent valves then the cylinder heads will need to be removed and repaired.
SOURCE: Timing Belt Problem-6 cylinder Saturn wont' start
If your timing belt broke, then it is possible that the valves in your engine got bent, which won't allow the cylinders to pressurize the fuel/air mixture, and it will let all of the mix to flow freely into the intake/exhaust manifold. This can be checked with a pressure tester that is threaded into the spark plug opening. A mechanic should have one, or you can probably find one at an auto parts store.
SOURCE: The lock mechanism on the
it is conceivable to remove the screws under the glove box assembly to help gain access to the lock mech. If this is not possible you might need to drill the lock. I am assuming you r not able to open the box. I f you are able to open it then replacing it is a breeze.
