Question about Funai PY90VG DVD Player/VCR
Everytime I record a programme and try to play it, the picture jumps throught. I cannot find a tracking button, is there one?
  • annkelly102 May 09, 2009
    Very many thanks for replying, I will try that.
    Ann
  • 909 Answers
No, it's auto tracking on that model. Check the condition of the tape you are recording on.
If its old it will record in poor quality, also try running a tape head cleaner, a wet one is best.
If that solves the problem for a while, say 3 or 4 plays, then it returns then the tapes are old and probably not usable.
I hope this helps.
Posted on May 09, 2009
Recording stops after 3 tracks have been recorded everytime
Are you exceeding the 74 minutes or 80 minutes of the disk?
Did you record some tracks from the computer or on a stand-alone recorder? If computer, you need to totally erase it to play 'sp' recordings again.
Jan 22, 2010 | Sony Audio Players & Recorders
Records fine but playsback with poor picture quality. Tape will playback on another recorder fine.
The video heads are dirty. Clean the heads and your picture should be fine. If a cleaning tape does not clear up the problem, try running a blank tape throught the unit from beginning to end in play mode.
Keep us posted.
Dan
Sep 08, 2009 | Toshiba Televison & Video
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Machine appears to record per instruction manual but will not play anything back and the instruction manual includes NOTHING on playback except to hit STOP when we're through recording, back up to the...
it appears to be recording but is it really?
when you are recording there are two levels you should see moving up and down on the screen. the input volume and the recording volume per track. dont forget to arm the track. tascam has a silly way to arm the track on some of there unit. its combination of buttons. something like hold down the record button and press the track arm button then release both. when youre ready to record press play.
Feb 22, 2009 | Tascam DP01 All-In-One Recording Package...
My tracks don't play in the recorded order, list I made them.....
If song tracks jump or skip then it is problem of cd player like optical laser is dirty / clogged,
and if track doesn't jump or restarts in middle of playing back then cd player is just fine,
Please check cd creator software settings.
Dec 18, 2008 | Sony CDX-MP40 CD Player
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
Jun 18, 2008 | Tascam DP01 All-In-One Recording Package...
Philips DVDR75
Try a lens-cleaning DVD. If the problem persists, the internal drive will probably have to be replaced.
Nov 29, 2007 | Philips Recorder DVD-R72
While playing back a recorded programme picture is lost and AV2 appears on the tv, sound can be heard on recorded programme playing back.The t.v screen goes black av2 appears in the left hand top corner,...
Does it do so on all tapes? It sounds like you are experiencing a tracking or tape path problem. You might try taking the top cover off, then cleaning the video head. Info is available on the 'net on how to do this. If problem remains, play a tape and see it is wandering up/down across video head. See if any of the tape guides are broken or bent, causing tape wandering. you may also have a problem in the electronics, perhaps in the servo circuitry, which has to do with careful control of tape speed, video head rotational speed, and certain other parameters. If electronics are bad, then VCR is likely a tosser, unless it is a high $ rig. Most electronics are disposable these days, unfortunately.
Mar 08, 2007 | Sony SLV-SE730 VHS VCR
Funai PY90VG DVD Player/VCR Logo
90 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
