Question about Microwave Ovens
Some of the key pad doesn't work any more
I have an over the range Maytag microwave. MMV0005DQ Some of the key pads do not work, A few still do work.
The contacts on the electronic board inside the oven for the display need to be cleaned. You should be able to get into the microwave from the back and unscrew the board. One side of the board will have a row of contacts that can be cleaned using first rubbing with an ink eraser and then with a q tip dipped in isopropanol (rubbing alcohol).
I lost all contact with the display on my microwave and this really helped get the key functions back.
Neil
Posted on May 21, 2009
My microwave oven start button is not working
The key pad is probably worn out or otherwise broken. Unfortunately, to replace the key pad/control board, if it's still in production, usually cost as much as purchasing a new unit. Sorry to be the bearer of bad news.
Aug 15, 2015 | GE Profile Spacemaker Over-the-Range...
Our lg stainless steel overthe range microwave oven will not start. When pressing start only says power 100
The touch pad could be the problem. Touch pads are notorious for going bade. the door interlock switches could also be a problem. Check to see if all the pads work if they do it could be just the start pad that is bad.
Mar 14, 2015 | LG Over-the-Range Microwave
Touch pad doesn't work
Your touch pad is connected to your board with a ribbon wire, it has probably come loose. Unplug the unit and remove the face plate. Pull it back and you will see the wire, it looks like a ribbon, push it in tight, replace the face plate and it should work properly. I see this happen all the time.
Sep 12, 2017 | Maytag Microwave Ovens
What is part i need to correct
You need to replace the keypad along with the attached control board, price $100.00 or more.
May 07, 2012 | Maytag Appliances Over-the-Range Microwave...
Maytag MMV5186aaq touch pad doesn't recognize touches on all pressure points. I can't even set the clock.
That looks like you are in need of a replacement key pad.
I can't advise where to get one from as I don't know which country you are in.
Mar 14, 2011 | Maytag MMV5000 Microwave Oven
No power in the microwave but there is electricity at the wallplug
No power and or NO lights at all,indicate a blown fuse.
Locate and replace the fuse inside the unit.
Feb 25, 2011 | Maytag Appliances Over-the-Range Microwave...
Maytag Range gives a F3 Code. The oven does not work
F3 usually depicts a front panel fault, a shorted key/touch pad contact is favourite.
Hope this helps.
Nov 22, 2010 | Microwave Ovens
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
