Question about Maytag MAV7600 Top Load Washer
Leaking Your advice about lubricating the motor was great but I found out that it's major leaking the whole cycle. I've heard that's a big time problem to fix so your advice bought me some time. thank you!
  • clunker Oct 30, 2007
    The leaking seems to be all around the base of the drum.
  • clunker Nov 20, 2007
    HELP!!!!! It has gone from bad to worse. Now it just stays in spin mode. The wash cycle is a slower spin and doesn't agitate at all. It's like the thing that would keep it from spinning is gone. I open the top and it used to stop but now it just keeps going. Is this machine worth fixing? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 94 Answers
Inspect the hose that connects the drum to the pump for leaks.
Posted on Oct 14, 2007
Metamec spring driven pendelem clock won't chime how can I resolve this problem
Mine won't chime any more and a repair man tells me a part has worn out and needs replacing. Over time they all wear out.
Jun 12, 2017 | Chime Home
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
Motor rattle on start up
I've never heard a Capacitor make a noise, but there's a lot of things I haven't heard, I have however, heard the start up windows make a noise when they start. One type pulls the start up relay in for the start up windings and can cause a noise sometimes. I wouldn't get in a big hurry to buy a new Refrigerator. Most of the time they do that for years and still work. Just guessing that that is the problem, have to hear it to know for sure.
Jun 22, 2012 | Frigidaire FRS23R4A Side by Side...
How to change heating core
this is a big job and requires the whole dash taking out ,as a stop gap measure join the heater pipes together so it doesnt leak inside the car but it will be cold to drive at this time of year .
Feb 06, 2012 | 1998 Chevrolet Cavalier
I have an F&P MW612 washing machine that stops at the start of the spin cycle leaving water in the machine. After pushing the pause button, looking inside, closing the lid and restarting I've heard...
Something may have been stuck in the drain pump impeller creating the clanking noise. This is a serious problem that can lead to the burning out of the motor controller module, the machine's "brain". It has been found that a short circuit is imminent on a leaky drain pump which can eventually burn out the motor controller module.
Empty the machine then lay it's front on a padded floor/surface and check the drain pump including the diverter valve where both the drain pump and the recirculation pump connect from. Replace the drain pump if damaged or leaking to avoid further damage to the motor controller module.
Fault Code Reading on Fisher and Paykel Top Load Washing Machines
Aug 23, 2011 | Washing Machines
Just bought and turntable won't turn
If it's under warranty, take it back.
I think the turntable on this model is driven by a synchronous gearmotor in the bottom of the oven, but it may be driven by a belt connecting it to a motor somewhere in the back behind the big transformer on the right side. (If the motor is under the oven cavity, there is probably an access panel on the bottom of the oven.)
If you know how to work safely around high voltage circuitry, you can check for voltage at the motor terminals to verify that there is no electrical fault. Sometimes the lubrication in the gearbox fails and the motor stalls. I've heard you can occasionally gets these to work by putting the gearmotor in the sunny-side window of a car to get it really warm, then squirting a few drops of light oil on the gearshaft next to the motor casing and putting it in a cool environment. If all goes well, the contraction of the air in the gear box sucks the oil in and it thins out the lubricant.
Jul 04, 2011 | Goldstar 79602 / 79609 1000 Watts...
Motor Oil Leak in the back area of my 4runnerany advice?
a possible problem could be the crankshaft oil seal. that you can found at the lower back of the engine. where the trans axle (transmission) attach to the engine. it's a major job that need to be the work of under chassis mechanic.
Apr 06, 2011 | 1993 Toyota 4Runner
Maytag MAV7600 Top Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
