Power switch is on very very slow for post at that time num lock is on position then monitor light yellow no display for bios configuration, then key board is not working monitor light is red
    Sergeant:
    Champion:
  • 212 Answers
Sounds like a hard drive issue. replace the hard drive
Posted on May 23, 2009
Could you explain what the symbol of a closed padlock with the figure 1 beside it on the Touch Sensitive Control area indicates?
Hello Jack, I believe that the symbol means that your number lock is turned on. The way it got turned was at least two ways that I can think of. 1. The computer's BIOS is configured to turn it on when powered up. 2. You may have done this yourself by accident. The Num lock is also activated by a function key combination on the keyboard. To turn the lock on or off you locate the FN key at the bottom left side of your keyboard. Now on the top row of keys locate a shadowy outline of the words NUM LOCK. Press and hold the FN key and tap the NUM LOCK key. The light should go out. If there are further problems please return and post them here.
Nov 29, 2013 | HP EliteBook 6930p Notebook PC
I bought a 2nd hand compaq evo D500 desktop whose power supply was dead.I kept it unused for 1.5 years.Now I have bought another power supply which is working fine BUT nothing is diplaying on the...
Check that you hooked up all the power supply connections. Try a new motherboard battery as the old one may be dead and the bios is not working. You are evidently not getting a post beep signaling that the cpu, ram, video are good.
Nov 27, 2013 | Compaq Evo D500 PC Desktop
"HP Pavilion m7580" is not
To verify whether it's a no POST issue, press NUM LOCK or CAPS LOCK key and check whether the CAPS LOCK or NUM LOCK lights are lit or changes when you press on it. If it doesn't then it's a No POST problem.
However, if the computer screen shows the HP logo or a display then it's POSTING and is experiencing a No BOOT issue.
If the NUM LOCK or CAPS LOCK responds when you press it but there is no display, check the connection between the monitor and the CHASSIS or CPU.
If you have verified that it's a No POST issue because CAPS lock is not responding, you need to open up the chassis to do a troubleshooting procedure. Be sure to unplug the chassis to all the connections especially the power cord. Drain the power by pressing and holding the power button from 8-10 seconds.
Here are the things that you need to do after you open up the chassis.
1. Reset the Memory sticks. Connect the CHassis to the power and monitor. If no go, try turning on the computer without the memory sticks. The aim of this troubleshooting is to see a display on the screen. Any display would be a good sign. If no go. Put the memory stick back in.
2. Remove the CD drive. Turn on the computer, check for development. If no go, proceed to step 3. Just leave the cd drive removed
3. Do the same thing with the other devices like the hard drive and other devices inside. Your aim is to see a display.
Let me know if what happens and I'll get back to you.
Once you see a display. Let me know by replying to this thread.
Apr 07, 2011 | HP Pavilion m7580n PC Desktop
My fan is running but it won't load windows. The monitor says power saving mode
Check the NUM LOCK led status when power on the computer if it is on and off when you press num lock key that means your cpu is working fine only issue with screen resolution for that when you power up th computer press F8 key 5 to 6 times then you can see safe mode and other menu.Enter in "enable vga mode " then go to display settings change scree resolution to 1024*768 then check. but if num lock led stay constant then open cpu cabinet cover reconnect RAM memory.Pull cmos cell from motherboard for 10 minutes then put it back. Reconnect pci or vga card if any. Reconnect processor and it's fan. Make sure motherboard is not ground with cabinet.Also make sure harddrive is recognized in bios if you are able to see bios. For that when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then check. Let me know if you need further assistance. Thanks for using Fixya.
Dec 11, 2010 | IBM ThinkVision L170 17" LCD Monitor
Hi I wonder if you can help me. I have the flatron L1918S monitor and it was working fine yesterday, however today when i turned on the pc, the monitor flashed the green light on and then goes into power...
When after power up the computer press num lock key if num lock led is flash on and off when you press num lock key then your cpu is working fine.But if it stay constant then open cpu cabinet cover then reconnect RAM memory and processor and it's fan pull cmos cell from motherboard for 10 minutes then reconnect it then check.Make sure motherboard is not ground with cabinet. If num lock led is on and off then when you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "Enable vga mode" then go to display property ->settings change screen resolution to 1024*768 then apply and ok. then check. If everything are fine in cpu then your monitor need repairing. Let me know if you need further assistance. Thanks for using FixYa.
Aug 25, 2010 | LG Flatron L1919S LCD Monitor
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
I have a Dell monitor that was donated to our church and all that comes on the screen is a white. the power is on but there is nothing but white light
Please check that when u power on ur computer then the Num Lock Key of Key Board is on or off.
1- If num lock key is on & monitor is displaying white screen then the problem is with ur monitor. For that u check the VGA cable going from monitor to back side of ur CPU & also set the brightness & contrast from ur monitor menu Setting.
2- If num lock key is off then the problem is with the RAM (Random Access Memory) which is placed inside the CPU. For that you have open the CPU, detach the RAM & clean the dust from that & then attach that at the same place.
Some times the Display problem is also comes across due to moisture, & for that you have place ur monitor in the sun light.
Hope after following these steps your monitor Display Problem will be get solved. If still you face the same problem then please let me know.
Nov 09, 2009 | Computers & Internet
Monitor will not turn on
First check your num lock key on key bord if it is on off when you press num lick key then your dispaly is working fine means you need to change screen resolution.
For that when you power up the computer press F8 key then enter in enable vga mode.then go to display property and change screen resolution to 1024*768 or 800 *600.
Also when you power up the computer press F1 or F2 or 'del" key to enter in bios then load optimal defaults also check your harddisk is detected .Disable your satat option in bios .then save settings then check.
I f you not able to enter in bios then Refix your ram.If still face problem you need to reset bios .
For that you have to open laptop cover in back then pull cmos cell from mother bord for 5 minutes then refix it then check.
Jul 27, 2009 | HP Pavillion dv9740us Notebook
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
When i log off and the next user logs on the keys on the keyboard are wrong i.e. the j is a 1 the k is a 2 the l is a 3
The number lock key has been pressed or the BIOS configuration has been configured with the NUM lock on.
Check the BIOS setting.
To release the NUM lock.
Press the number lock key once, if you press it again it will turn the numbers again. It is usually one of the keys above the Function keys (ie F1 to F12 keys).
Mar 09, 2009 | Sony Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
