Question about Canon LASER SHOT LBP-2900 Printer
Primnting paper is crushed and unreadable
  • 400 Answers
It's a problem with the fuser assembly on the printer.
If it still has warranty then you will have to take it back.
Otherwise you can try and open the printer at the back and see if there is any jammed or stuck paper on the fuser assembly ,its the part that melts(fuses) the toner onto the paper.
Posted on May 15, 2009
Paper for till pad
considering that ,that machine is still new , it will be hard for you to get it from a non dealer. Your best bet will be a casio dealer. Depending on where you are bur Casio is well represented world wide.
May 07, 2014 | Retail Supplies
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
Printer crushes paper sideways while flashing exclamation point indicating paper jam.
If you can't see inside the back where the paper goes, then turn your printer upside down and shake it good, see what falls out of where the paper should go...
Oct 29, 2009 | Dell 922 All-In-One InkJet Printer
Printing paper with to much toner ink on the paper. Words are unreadable.
If this is a cartridge refiling case,
I think its an over refill
try with refill again (complete empty (also waste) is necessary for best result)
May 21, 2009 | Brother Office Equipment & Supplies
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
Size of received/sent fax
you must have the reduction mode on in the fax section. This allows incoming faxes that are larger than the size paper you have available to be printed. You may have you paper set in a direction or size paper that is not the same as the fax being sent.
Nov 17, 2008 | Panasonic Workio DP-1820E Copier
Printer paper Allignment
I hve tghe same problem. DId you gt it fixed?
May 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Stretched-looking faxes
It is probably from the same sender I bet. He has an original paper feed problem. If not let me know.
Jun 14, 2007 | HP 1040 Plain Paper Inkjet Fax
Canon LASER SHOT LBP-2900 Printer Logo
49 people viewed this question
old marine
old marine
