Question about Zephyr Sport & Outdoor - Others
I have a baquapure sand filter please help
I have sprung a leak in the big blue ball what can i use to fix this
If leak is around the top 7-way valve it is probably the rubber o-ring underneath that needs replacing. if the tank itself has a crack or hole you could try something like j/b weld to patch the hole.
Posted on Jul 01, 2009
  • godawgs2314 May 23, 2011
    Does anyone know where I could find a baqua pure multi port valve?
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
My Hayward Sand Filter Tank has sprung a leak on the side of the tank not near where it looks like the tank might have been molded together. What can I use to patch the tank that will hold and not leak?
They are fiberglass ... fiberglass repair kit should do it ...
Im not so sure I would fix it ... if it is broken ... there are probably problems you cannot see ... might be cheaper to replace the tank when you consider what might happen if it breaks while you are not around.
Aug 29, 2010 | Hayward SAND FILTER, PRO SERIES
How do you get the Trimline Ball Valve off?
First if it isn't cracked you should be able to remove the screws from the top and replace gaskets inside. There are two types the clamp ones and the threaded ones. The threads get difficult with plastic on plastic (or fiberglass) and sand in the threads. If it is indeed no longer of any use, thread a piece of 1-1/2" pipe in the vale openings. Apply some type of lube to soak into the threads. Get an assistant to hold the filter , while you use that pipe as a large wrench to remove valve. REMEMBER LEFTY LOOSEY. That valve will be rather expensive,and not easy to locate. Try repairing it first.
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
Sand leaks into pool. I took apart the vari-flo control valve and found that the rubber that fills the top of the dividers in the piece that has 6 sections in it has eroded and come out. Could this be why...
Thank you for posting your question here on Fixya.com.
You need to empty the sand out and replace the lateral assembly too. It attached to the bottom of the valve and has several 'fingers' embedded in the sand. Once it wears enough, the sand can get thru it. Replace the sand if it is over 3 years old while you are at it. A wet/dry vacuum works well for removing the sand.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 12, 2010 | Hayward Pro Series 18" Above Ground Pool...
Hayward sand filter leaks
You can try different epoxy's but they usually won't hold as the filter expands when running this will break any seal where you put it.You can check into warrentys. A lot of these filters had good warrentys on the tanks that went longer than valve or internal's. if you have install dates and model #'s. Check on line with Hayward.
http://www.haywardnet.com/inground/products/manuals.cfm
Worse comes to worse you can drill out a small hole amd using stanless steel go with a bolt and nut with washers and rubber washers in the middle. when you set it seal it all with silicone and after it is tight let it set for eight hours or so. Good luck.
May 28, 2010 | Hayward SAND FILTER, PRO SERIES
To much sand coming out of my hayward
If it is sand in pool you may have a broken ladderal inside the filter. Big job to fix. Call a pro. If it is just silt and fine dirt you may be able to help this by putting a small amount of DE into the filter and it will clear up most fine dirt. If not your sand may be clumping and should be replaced or a new filter may be in order. Once again big job and time for a pro. The out look is not good. Sorry.
Dec 28, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter not filtering small particles
You probably have too big of pump. It is pushing the finer stuff right back into pool. Try adding a clarifier. Don't backwash either until the pressure goes up.
Jul 30, 2009 | Hayward Pro Series 18" Above Ground Pool...
How much sand does it take for a BaquaPure 22 gal. tank?
if the tank is 22" you use 100 lb. 24" 150 lb 26" 200 lb.
50/50 silica sand works best.
Jun 25, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
847 people viewed this question
Top Zephyr Sport & Outdoor - Others Experts
Bill Eager
Are you a Zephyr Sport and Outdoor - Other Expert? Answer questions, earn points and help others
