HP Pavilion dv7-1132nr Notebook PC Logo
Dwight Thompson Posted on Nov 29, 2013
Tsst corp CDDVDW TS L633L SATA CD rom device
Updated clean install windows 8 from vista, Now player dosent show up and usb device don't show up when I put it in
mroshs
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 29, 2013
mroshs
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
723
Points
12
Install updates from microsoft
2 Related Answers
TampaNative
Frank Fernandez
  • 778 Answers
  • Posted on May 25, 2009
SOURCE: lost cd-dvd rom driver for a TSST Corp CDDVDW TS-L632N ATA DEVICE DRIVER
You can select your Operating System since you didn't mention it and continue to your drivers page at the link below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3747228&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7&lang=en&cc=us
Anonymous
  • 7 Answers
  • Posted on May 29, 2009
SOURCE: TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
My TSST CDDVDW TS-L633L reads only and can not write since I wiped off the hard drive and installed a clean version of Windows 7 Pro 64 bit...Updated all the needed drivers but the above mentioned drive...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver if your computer came with a motherboard disc the drivers could be on it
http://newdd.pcdriversheadqu.revenuewire.net/driver-detect/download
this is only a free trial
hope this helps
2helpful
Acer Aspire 4535 with problem Take about 20mn to 3 hours to turn on the cd rom TSST corp CDDVDW TS -L633B SCSI CdRom Device cannot read cd and dvd
i think that you need a new cd rom drive but give me a little more information on it like what exactly is it doing and was it making any noises
Tsst corp cddvdw ts-l633b comes up cd drive not
time to shop for new one on
www.ebay.com
Usually one screw on the bottom of your laptop,the slide it out.
1helpful
My CD DVD player won't work. TSST CORP CDRW DVD
This is the latest driver released by TSSTCorp for thier devices.
If this helped please vote kindly
3helpful
Driver needed for TSST Corp CDDVDW TS-H653N
Download it from
http://www.megaupload.com/?d=YX4P99CU
would suggest, personally, to download that driver [File Version: 6.0.6000.16386 (vista_rtm.061101.2205) file, and use that file to overwrite the driver on your system, seeing as my drive functions. The file source can be located at: C:/Windows/System32/Drivers/cdrom.sys
That is what I'm showing as the latest driver at the moment. Hopefully that will be of some help.
11helpful
2answers
3helpful
Lost cd-dvd rom driver for a TSST Corp CDDVDW TS-L632N ATA DEVICE DRIVER
4helpful
TSST Corp CD/DVD RW TS-L632M ATA device wont play discs. Driver is current
I also have the TSST cd/dvd with the same problem but I just realized that is a comflict between all these programs I have installed (Windows Media Player, Sonic and Roxio Easy Creator 6). WMP will not even show it, then I went to Roxio audio central an it worked perfectly. I tried to change the default back to WMP but it wont take it. I believe this happens because Roxio was the last I installed and took control of the sound. Hope this help. I will be uninstalling my WMP and installing it again so that I can keep it as my first choice.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
