Question about Danby DWC283BLS Wine Cooler
Danby wine refrig
The wine refrig was unplugged from June through Sept.  We just plugged it back in but after 24 hrs it is warmer within the refrig than the outside temp.  Is there anything we can do....seems to be running but not cooling.
  • Lathangt Feb 13, 2008
    We turned off our Danby DWC283BLS wine Cooler in December before we went out of town. When we returned in February and plugged it back in, it started Ok, could hear it running, but the RUN indicator stays on all the time and the appliance does not cool. We followed the directions and unplugged it for 5 minutes then plugged it back in. There was no change, the compressor is running and there is still no cooling and the RUN indicator remains.
    lathangt@telus.net
  • Anonymous Apr 20, 2008
    Mon réfrigérateur ne refroidit plus la température de l'intérieur est la même que l'extérieur. Que dois-je faire? Je l'ai connecté et disconnecté et il n'y a pas de changement.
    Novelist:
  • 114 Answers
THE LAST THING THAT EVER HAPPENS IS FREON LOSS.
SO TRY THIS FIRST ...
LET THE COOLER STAND WITH "NO POWER FOR 24 HRS.
MAKE SURE IT INSIDE AT ROOM TEMP. NO HIGHER THAN 75 deg. AFTER THE ALOTTED TIME TURN THE T-STAT-"OFF" AND TURN THE POWER "ON" ...
THE CONDENSER FAN SHOULD START IMMEDIATELY. NOW LISTEN REAL CAREFULLY BY THE COMPRESSOR TO HEAR ANY CLICK NOISE. IF YOU DO THAT IS THE EXTERNAL OVERLOAD ( bI-METAL SAFTEY T-STAT THAT PROTECTS THE COMPRESSOR. TURN POWER OFF AGAIN AND DO THE FOLLOWING.
THERE IS : 1) A START (plug-in) RELAY THAT PLUGS INTO THE COMPRESSOR.
2) THERE IS A START ASSIST CAPACITOR MOUNTED USUALLY ON THE TOP OF THE COMPRESSOR TEREMINAL COVER.( THIS IS HELD ON WITH A METAL STRAP THAT CAN BE "POPED-OFF" WITH A SCREW DRIVER. OR IT MAY HAVE 2 MOUNTING SCREWS.
3) THERE IS A ROUND BI-METAL T-STAT THAT PROTECTS YOUR COMPRESSOR.(AS STATED ABOVE).
MAKE A DRAWING OF WHERE EVERY WIRE GOES AND THE DEVICES ON PAPER. .... THEN ... AND ONLY THEN REMOVE ALL 3 PARTS AND TAKE THEM TO YOUR LOCAL APPLIANCE REPAIR OUTLET. eg. APPLIANCE PARTS. APCO ETC.
THEY WILL CHECK ALL 3 COMPONENTS FOR YOU AND MOST ALL HAVE UNIVERSAL REPLACEMENTS FOR ALL 3 DEVICES NO MATTER WHAT BRAND YOU HAVE.... AND THEY SHOULD BE ABOUT $10-$15 EACH.
I HAVE REPAIRED HVAC & REFRIGERATION EQUIPMENT FOR OVER 40 YEARS. WHAT I DO IS REPLACE ALL 3 DEVICES. IF ONE IS BAD IT TENDS TO OVERHEAT THE OTHER COMPONENTS AND WEAKENS THEM.
NOTE: NEVER INSTALL REFRIGERANT SELFTAPPING VALVES TO CHECK FOR FREON ... A AMP DRAW WILL TELL YOU IF COMPRESSOR IS RUNNING AT FULL LOAD , AND AT THE EVAPORATOR YOU SHOULD HAVE A 10-20 DEG F. DROP IN TEMP. YOUR EVAP COIL SHOULD FORM A EVEN FROST ON IT IN ABOUT 2-3 HOURS.
THE MAIN THING IS TO ENSURE COMPRESSOR IS RUNNING.
IF YOU HAVE A THERMOMETER, THE LARGER COPPERLINE ON THE COMPRESSOR SHOULD BE ABOUT 50-60 DEG.AND EVENTUALLY WILL "SWEAT". THE SMALLER LINE SHOULD READ 120-150 DEG "AT THE COMPRESSOR" OUTLET CONNECTION.
MAKE SURE YOUR CONDENSOR AND EVAPORATOR COILS ARE BOTH ABSOLUTELY CLEAN. (CHECK WITH SMALL BRIGHT FLASH LIGHT TO SEE THROUGH COIL FINS.
THAT SHOULD SOLVE YOUR PROBLEM. YOU MAY FIND WHEN TAKING THE PARTS OFF ... A BROKEN OR BURNT WIRE. IF SO REPLACE IT WITH AT LEAST #12 STRANDED WIRE.
PROPER WIRE AND TERMINALS ARE AVAILABLE AT THE APPLIANCE PARTS STORE IN YOUR AREA.
GOOD LUCK ... JOE_REX
Posted on Oct 12, 2007
  • Joseph Reckinger
    Joseph Reckinger Oct 12, 2007
    CORRECTION AFTER TURNING "THE COLD CONTROL' ( T-STAT in side cooler) "OFF" AND POWER "ON" AFTER 24 HRS. TURN THE COLD CONTROL T-STAT SETTING TO MID DIAL RANGE FOR NOW. IF THE CONDENSSOR FAN AND COMRESSOR FAIL TO START. UNPLUG THE COOLER AND JUP-OT THE WIRES TO THE COLD CONTROL / T-STAT. IF THE COLD CONTROL IS GOOD ... ONCE IT RUNS FOR A GOOD 8 HRS .. IT SHOULD START CYCLING OFF AND ON ON THE COLD CONTROL. ADJUST TO YOUR SPECIFIC SETTING TO MAINTAIN 50 DEG. FOR WINE.
    Joe_Rex
Never unplug the refring
Posted on Nov 23, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
A) Possibly the refrigerant has leaked out
b) The compressor has tripped
Refrig door was not completely shut fof about 24 hrs temp was 50. Makes a loud noise when running and about 8 hrs after discovery has only gone to 46 degree
Listen to sound where is it coming from bottom back? Or inside near back wall . noise could be ice on or around evaporator fan if you can unplug for 12 hours leave doors open this will melt ice . if it is ice that will fix it.
May 08, 2015 | Gladiator GAFZ21XXMK Bottom Freezer...
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
My danby wine cooler does not get cold enough
Cool enough? You know most wine and beer only like it about 50 degrees and not any cooler. If it up at 55 and you have set it lower then the room is probably warmer then it can handle to cool them. I have some in the garage but in July and August the struggle to stay any cooler then 55 but then they are not expensive units either. Danby is cheap brand too. Nothing they make is that great.
Oct 07, 2014 | Danby Refrigerators
Danby Silhouette DWC513BLS lower back fan noise.
Called Danby customer service. Requested repleacement part of lower fan unit. Located at bottom right on back of unit. Part was $6.68 plus shipping. Less than $10 total. At my door in 3 days. Plug and play piece that was easy to change. A very cheap fix and I hate to think what a service call would have been. Danby ph # is 800-263-2629.,
Dec 08, 2008 | Danby Silhouette DWC512BL Wine Cooler
Where to buy parts for Danby dual zone wine cooler?
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Here is a fix ya sponsored site to get parts1
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?gclid=CILtivXM_pUCFQIWFQod8lGGEg
Huuum
Please remember to leave a rating before you go!
thank you
Aug 26, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
614 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Danby Furniture Expert? Answer questions, earn points and help others
