Question about HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
Chang mainboard - HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
    Scholar:
  • 48 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Hello, I will list the steps it will take to complete yourtask to the best of my ability. It is hard to write how to do something likethis but you should be ok if you just use a little common sense.
Things you will need: Static Wrist band (Optional) and some Thermal CompoundSuch as Artic Silver 3 and your New Mother Board manual. I would also have someQ-Tips and Alcohol on hand
Tools: A Screwdriver set (Non-Magnetized) and a small socket set or nut driverset
If you decide not to use a static wrist band you must always ground yourselfbefore touching any of the electrical components. This can be done by grabbingthe metal portion of your case with one hand and pull the parts with the other.
1. Find a nice flat surface to work on and lay an old towel down.
2. Un-hook all cable from your computer
3. Lay your computer on the towel and pull the covers.
4. Open your new Mother Board and take it out of the static bag. Lay the newMotherboard very close to where you are working. But lay it on top of thestatic bag.
5. Start pulling all your components from the Mother Board IE: Sound Card,Video Card, RAM and any other component that is plugged into it. Now would bethe time to insure that the new Motherboard is compatible with all yourcomponents. Look at the plug styles of you Video Card, Sound Card and RAM toinsure the are the same style.
6. Now I would unplug all the wires from the motherboard except the very smallwires that control your reset button, power and lights. These will be last.
7. Ok once you have unplugged everything but the control wires start taking thescrews out of the Mother Board. When n you get all the screws out slide theboard a little to the right (To get the Plug ports out of the case)
8. Now with the Power, LED and reset wires still hooked up.(This should be the only thing still plugged up) lift up and lay the old motherboar on the upper corner of your case in a fashion that it will sit withoutholding it.
9. Now grasp your new board with the static bag still underit and sit it on the corner across from the old boar. You now need to locatethe pins on the board that the LED, Power and reset wires plug into. If theyare not marked on the board you will need to look this portion up in yourmanual to figure out which pins go to what.
10. I would now (Once you locate what pins do what) Unplugeach wire from the old board one at a time and plug into the new board.
11. When all the wires are on the new board move the old oneout of the way. (Depending on how old your case is you might need to usespacers that usually come with the new motherboard to line up with the plugports on the back of the computer)
12. Now do everything in reverse order.
If your new motherboard did not come with a new Processor youwill need to pull the old one before you install the components back to the newboard.
  1. Take the fan off of the top of the processor on the old board by taking the screws out. Once the screws are out carefully wiggle the fan back and forth until it frees itself from the processor.
  2. Now you should take some alcohol and clean the old silver off the top of the processor. Once its clean you will see a lever on one side of the processor you will need to un-pin and lift upward to free the processor.
  3. Once free carefully lift the processor out of the socket and lower it into the socket on the new mother board. This will only fit one way and don’t force it or you will bend the pins. It should freely drop into the socket as long as your lever is in the upward position. Now you can snap the lever back down to lock it in place.
  4. Take a little more alcohol on a q-tip and clean the top of the processor again to get any oils or dust off. Now apply a small amount of the Thermal Silver to the top of your processor but cover the whole area.
  5. You can re-install your fan and plug it into the motherboard.
I tried to be as descriptive as possible and if you know alittle bit about computers your will be able to replace the motherboard withoutan major problems from this list. Some things in this process are common sceneso just think about what your doing and move slowly. I hope everything goeswell and if you have any questions feel free to ask.
Posted on May 09, 2009
Error code 03130031-2618
It mean "Vh voltage error" and can be cause of short circuit in the printhead . Sometimes you can get good result with printhead changing, but it is not guarantied because of possible printer electric parts (carriage board, flat cable, motherboard or power supply) damage. For printhead changing, delete paper and use Service mode (hold Paper sourse + Information while switching printer on).
Apr 13, 2015 | Canon imagePROGRAF IPF710 Printer
How do i change the battery on a ipad generation 3
You have to remove the digitizer with a heat gun then remove the LCD disconnect all ribbon cables from mainboard remove mainboard to disconnect the three batteries. 2_3_2014_8_45_18_am.png
Feb 03, 2014 | Tablets & eReaders
Acer aspire 5943g
Hello you can ask your local acer shop to order a new mainboard.
But it will cost more than a new laptop to change the mainboard.
The price is approx. 500 dollars for the mainboard.
Without the cost to change it.
The home page is here:
http://support.acer.com/product/default.aspx?modelId=2437
Hope this will help you
Nov 19, 2012 | Acer Computers & Internet
Canon ipf750 error 03130031-2618
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit.
Mar 01, 2012 | Canon imagePROGRAF Office Equipment &...
No video, i try unplgu power cord and power supply conectors, change microprocessor,change power supply, change memmory modules, clear cmos
Hello
either your video card is faulty or if its build into the mainboard then most likely the mainboard is faulty.
Jan 30, 2011 | Biostar U8668D (802700113338) Motherboard
NO power on motherboard
hi check this list in that order
1- swicth on your power supply 2- power cable to the casing to the motherboard 3- your power casing swicth and reset (if the sw go on and off 4- clear cmos jumper 5- onplug your harddrive dvd all pci card ect.. evrerithing. keep only the minimum cpu ram and videocard if you dont have one in your mainboard 6- change termalpaste 7- change ram 8- change cpu
and now if your mainboard dont start your mainboard is dead
good lock
Oct 21, 2009 | MSI 845 PRO Motherboard
Samsung 32" LCD TV
Attention, noisy pictures on dynamic image does not mean to change the main board, most of the time , the panel need to be replaced, not the main board.
Jan 08, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
HP Compaq dx2300 Microtower - RT950UTABA PC Desktop Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
