Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman lawn tractor 21.5 hp, model no. 917.272463. The engine starts well, but while running it spits and sputters every second or so, whether at idle or at full throttle. I changed the fuel filter Spring of last year; air filters are clean, spark plugs are good. Gas in tank is fresh. I have never had this problem before. The tractor was just used last week with no problems. Your help would be greatly appreciated.
  • Anonymous Mar 23, 2014
    tractor will not run after having fuel filter changed and has fuel
    Sergeant:
  • 322 Answers
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
Posted on May 09, 2009
21 horsepwer enine smoked and then stopped running
Check the oil is it low...some engines have a low oil shut down...and will not start or run when too low Good luck
Aug 04, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 21 hp lawntractor model 917.289240 will no go in reverse.
If this is a hydro unit and it runs ok forward there should be no other reason other than linkage adjustment for it not to run in reverse, for safety reasons they are normally adjusted to run slower in reverse
Aug 09, 2012 | Craftsman Garden
It spits and sputters and then cuts off whats wrong?
is it loosing spark when this happens?is the gas cap vent plugged no allowing fuel to flow?
May 03, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I start the engine and it sputters at fast idle and then eventually shuts off.
I think that after you start the engine you need to move the throttle lever off what you are calling fast idle (which is full choke). Simply slide the throttle lever down until it smooths out and runs properly.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
21 hp electric start Craftsman lawn tractor, B&...
Have your mechanic set your intake/exhaust valves at .004 when piston is 1/4 inch past top dead center on compression stroke.
May 19, 2010 | Garden
I have a 21.5 HP 42in. deck mower that I just bought (used), having a little trouble with. Mower starts fine, and runs great... until it heats up, then it starts spitting and sputtering, blows out black...
The black smoke is too much fuel, it is flooding out. Carb issue, I would pull the float bowl and clean carb, the needle in carb is stuck open pumping too much gas in.
Mar 19, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
418 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
