Question about GE 29893GE1 Corded Phone
Full Memory The memory is full. How do I clear it? The phne is ringing more than I set it to because of this and the answering machine doesn't work now. Also, can I get a user guide for this product since I have lost the original one?
  • 3 more comments
  • madmaof4 Feb 28, 2008
    I have the same exact phone and issue. There is nothing that will fix it. We have tried everything. If someone does find a fix, let me know.
  • Anonymous Jul 11, 2008
    Memory Full is the problem and answerer does not work
  • ramos7500 Jul 24, 2008
    no messages on answering machine yet when incoming calls hear recorded message it says memory full and they aren't allowed to leave message.
  • 1951bUNNY Aug 02, 2008
    I have same problem and can't figure it out memory full tried everything even unplugging it if someone finds solution email at iwantout75@comcast.net
  • jmc27513 Feb 02, 2009
    I have a full memory on my digital phone. How do u fix it?
    jmc27513@yahoo.com
    Novelist:
  • 114 Answers
Go into your menu and see if they have a "FORMAT" or "RE-SET" option. If it does you can hit and click on yes to erase all memory and return it to Factory settings.
Good Luck
Posted on Oct 11, 2007
It rings a long time, then asks for a code number, no matter who is calling.
This sounds like a "full memory" situation: the answering
machine only has a ~12-minute capacity.
When the message memory is full, it cannot pick up and
take a new message ( ...its limited space is full...)
Ringing ~10 rings is an indicator to you, the owner,
calling in to check messages that it is full. It asks the
caller for the Remote Access Code so the caller (you)
can listen to & manage ( DELETE !) some messages.
Basically, you just need to clean up the answering
system by deleting old messages...all should return
to normal then.
Dec 29, 2015 | Uniden Cordless Phone
How to clear memory full
Memory is full on my answer machine at home how do I delete it y
Jan 14, 2014 | Panasonic KX-FT937 Thermal Fax Machine
CLEAR MEMORY ON CANNON FAX MACHINE
if you get the message MEMORY FULL to clear it just unplug the power cord for a minute or so.
But if you want to clear all machines memory, enter the service mode ( MENU and # ) select Clear and ALL.
After these you need to reenter fax settings, such as fax number, sender name, ring count,...
Hope that helps!
Aug 26, 2010 | Canon L120 Fax Laser Printer
Not receiving any incoming faxes
Is the phone line working? Do you have any devices connected to the phone line that pick up before the fax machine? Make sure the machine has paper and is set to FAX or AUTO. Is there a Memory Full error? Clear the memory (Setup > Memory Clear then press Start/Enter. Use the left and right arrows to select the items to remove. Press Start/Enter twice (second time to confirm the choice). Repeat until all memory is cleared that you wish to clear. Then press Stop to exit.)
If you are using the ANS/FAX mode and have an answering machine connected to the extension port, disconnect the anwering machine and switch to FAX or AUTO. Check if the machine receives faxes. Sometimes the extra device causes interference. Call the fax machine from a different phone number and see if you hear the fax tones.
Check that the Junk Fax barrier is off, if the incoming call is from a machine that is not listed in your speed dial database. If you have a distinctive ring, make sure that the Fax machine has learned the ring by pressing Setup go to DRPD. Choose Set and call the fax machine from another phone. The LCD will say Waiting Ring until it gets that call and then once the ring is learned will say END DRPD Setup
I hope these ideas help.
(If you have a phone company voice mail service, the faxes may end up stuck in that box. It depends on how many rings the fax is set to wait before picking up versus when the voice mail opens to take the call.)
Jul 16, 2010 | Samsung SF-515 Plain Paper Laser Fax
On Model 1725 get message F1, how do I clear it, etc? John
CLICK HERE for your owners manual in PDF format.
F1 indicates a communication failure with the digital EEPROM (onboard memory).
Essentially you have a paperweight now.
The repair requires a replacement of the memory module, and from all accounts, that proprietary part is not sold.
I would also assert the repair to cost more than another unit (new, or used)
Thanks for using FixYa!!
Sep 03, 2009 | AT&T 1725 Answering Machine
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Feb 17, 2009 | Uniden TRU8885 Digital Answering Machine
Says memory full but nothing in memory
Memory full errors can be caused by a couple of things. When you send a fax the machine settings and the amount of installed memory can cause this. Check the resolution you have the fax machine set at, usually it is set on something like "text" or "draft", if it is set on somthing like "fine" or "super fine" you will fill up the memory faster. Also if you are loading the document into memory before it actually connects with the other machine this could happen. Try looking for a switch or setting on your machine that says "direct". If you have a direct send enabled, your machine will not load the image into memory, it will wait for the other machine to answer and start receiving before actually doing any transmitting of the document. These are just general ideas as you did not describe the make or model of your machine. Hope this helps.
Larry
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Answering machine NO:26998GE1-D
there is a button on the bottom of the 'cradle' of the phone next to the places where the cords are plugged into the cradle
Oct 12, 2007 | GE 29878GE1 Digital Answering Machine
Receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Sep 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
GE 29893GE1 Corded Phone Logo
230 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
