Question about HP Color LaserJet 3500 Printer
HP Color LaserJet 2600 Printer color shifting
Pls. look at the attachment, my hp CLJ 2600 printer images shows all color shifting except black one.. excactly i dont know, may be color is shifting and rest is ok.... so i believed that problem was from the printer... so i've done the firmware update... and restored defaults from service menu but it worked slightly...
Pls.. give me solution...
  • 527 Answers
This will solve the problem... check out this link
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 09, 2009
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
My hp CLJ 1600 misaligment colors black go left yellow and cyan are ok and magenta goes right. I try calibration no effect
Hi bojan,
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
HP Printer Support
Feb 26, 2014 | HP Hewlett Packard LaserJet 1600 Printer
Hp laserjet 9500 is showing error 59.6k. and asking for restar.after re start error is same pls solve this issue
59.6K is a problem with the black image drum.
Take the black cartridge out of the printer. Shake it, reinstall it. Power cycle the printer. If the error comes back, remove the black image drum and reseat it. The image drums(one for each color) sit below the toner cartridges.
If the error still comes back a tech is going to have to look at the printer.
Apr 04, 2011 | HP LaserJet 9500hdn Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
HP Color laserjet 2600 only black print is commong
It a problem with printer fusing assembly. so you can checked it from service center.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Disassembling q6002 cartridge
if the your printer are hp clj 2600 then open door and then you can easily remove all cartages one by one
Jul 13, 2008 | HP Color LaserJet 2600n Printer
Hp laser jet 2600n
firstly ckeck the data cable is connected in your pc or not
in your pc go start setting printer and faxes and in this window you can show your printer
then ckeck it it is ready or not
if it is ready then open the printer clj 2600 and ckeck the few command pending or not if the command is pending then concle it and then give printouts
if the printer is offline then goes printer properties and ckeck printer properties
Jul 12, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 3500 Printer Logo
294 people viewed this question
Seeker5211
Seeker5211
