Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
How to remove the inside back pannel of a LG Refrigerator
I was wondering if anyone know how to remove the inside back pannel of a LG -LRSC26922TT. I m trying to check if my defrost header is OK as well as the Temperature Fuse.
Thanks,
Mike
  • 5 Answers
SOURCE: GE Refrigerator Side by side Model# PSS26NGSA
sounds like motherboard failure take panel cover off and inspect you may even smell a burning like plastic smell on board
Posted on May 16, 2008
  • 93 Answers
SOURCE: Hello,
usually it is not the heater but the controller for the defrost.
Which is a plastic package on the side if the coil, plugged into the roof.
Replace it, they are not expensive and testing one is.
Posted on Sep 12, 2009
Testimonial: "Ok, thank you very much. i will replace it."
  • 4793 Answers
SOURCE: automatic defrost refrigerator not cold enough
manually defrost unit. no hot water... clean out drain hole with thin wire with a small cloth tied to end (very small amount ) dipped in clorine bleach. blow out if wire not available. clean around fan housing clearing any dust particles...plug in and check temp.all should be fine....manual defrost/clean drain, wash out interior with bicarb every 6 months.hope this sort it out ....
Posted on Feb 09, 2010
SOURCE: Hello, I have a GE Prolife side by side
Where exactly on the back wall of the fresh food compartment(refrigerator) is this ice build up? If its building up in the air vents, that usually indicates a warm air leak, and this additional warm air is creating condensation, read ice, where it meets the colder air. There is no defrost heater or sensor in the refrigerator, all the cooling components that need to be inside the cabinet are located in the freezer. To check for warm air leaks, check to see that your light switch turns the light(s) off, check that the door actuates the switch when its closed, you will have to close door and squeeze part of the gasket to see if the light stays on. Furthermore, check the door gasket itself, make sure there are no gaps, rips or other malformations. Check that the bottom part of the gasket is not sagging, or the hinge side corners are not bunched up, or stretched out from the corners. Also, let the door close by itself like normal, and check the lower portion of the non hinge side of the gasket, if there is a gap here, further check for scratches on the bottom inside liner, not the door, inside the bottom of the fresh food compartment. If there are scratches here, this indicates the door is rubbing on the bottom because its too low, indicating a problem in the lower door hinge area. You dont mention any refrigerator freezer temperature problems, so it does not sound like a defrost problem or an issue with an evaporator fan motor failure.
Posted on Nov 09, 2010
heatman101
  • 43501 Answers
SOURCE: My LG refrigerator (Model LRSC26922TT)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 25, 2011
My LG refrigerator (Model LRSC26922TT) in running constantly but not cooling in either the fridge or freezer. Is this a fire hazard tonight? Is there anything I can do to fix it?
heatman101
Aug 25, 2011 | Refrigerators
I have a yellow film inside the refrigerator. I
You have a seled system leak call for service this has a seven year warranty.
Nov 23, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Unit not running, no lights on pannel but lights work inside.
Could be a control board issue, a broken wire somewhere, maybe the plug came off of the board. Try to unplug the refrig and plug it back in....A lot of times that will reset the board
Sep 13, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Same problem
connect ur phone to pc and and go to control pannel and remove it or u can go to ur phone disk and del all the stuff u wanted to del
Aug 22, 2009 | LG KU990 Viewty
LG refrigerator LRSC26922TT
You may can remove the dispenser cover and find the part of the water line that's leaking. Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Aug 14, 2009 | Refrigerators
Water leak from bottom freezer door
If you remove the back cover off the unit, you will see the compressor with an evaporator tray, make sure the little drain hose isn't plugged and that there is water in the evap tray from drain hose.
Jul 22, 2009 | Refrigerators
LG LRSC26922TT Water leaks under the filter need assistance on this please
turn off the water source to your refrigerator place a container under the filter housing, open the filter cover and see if any thing is under the seal, if not replace the cover , turn the water back on and check for leaks.
Jul 10, 2009 | LG Refrigerators
How do I change the blower fan that cools the door for the ice maker.It looks like the whole inside pannel in the freezer has to come out. Thanks
Carefully check under rubber seal to see if it has screws. If it doesn't then panel should just pop off. The rest should be straight forward. Remove and replace blower.
Jun 29, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Noisy vibration
Remove the back panel inside the freezer (if there's a removable panel there. There is a fan behind it - may be source of your problem.
Jan 22, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
89 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
