Question about Whirlpool 3.2 cu. ft. Plus Washer
Leak coming from bottom of washing machine
Washer is off and unplugged.  two days now and water is coming from underneath the machine.  what could be the problem????
  • 3 more comments
  • Anonymous Mar 13, 2008
    WE HAVE CHECKED ALL OF THE EXTERNAL CONNECTIONS AND NONE OF THEM ARE LEAKING. WHEN I RUN THE WASHER WATER LEAKS FROM THE BOTTOM OF THE MACHINE OUT OF THE LEFT SIDE. THE WATER IS TRICKLING OUT OF THE FIRST TWO SILVER TRAYS ON THE BOTTOM LEFT SIDE! WHAT COULD BE CAUSING THIS PROBLEM?
  • robSimons May 12, 2008
    I have water leaking from the left side of the machine when it pumps out. I cannot see any breaks in any hoses. Is there a tub seal that could be the problem? I had a problem of water out the front of the unit, i replaced the pump and that fixed that issue.
  • may200711 Aug 17, 2008
    Dear who it may concern:
    We have the same problem that you described in your latest artical and our washing machine is also leaking but it is leaking underneath the centre of our washing machine so we were wondering if you could email us back to tell us any solutions that could help us in this problem.
    Thank you
  • Anonymous Mar 21, 2014
    when washing machine is filling water starts coming from underneath
  • Anonymous Mar 22, 2014
    what parts are at the bottom of a washing machine that could leak
    Problem Solver:
It might not have totally emptied during the last cycle.  Try laying the hose where the water empties down.  The level of the hose needs to be lower than the water level to be able to drain.  Make sure you have a bucket to empty in to.
Posted on Oct 11, 2007
SOURCE:
The washer does not wash the clothes or spin them dry, come out smelling like they were not washed, water leaks from underneath, tries to start on its own and at times will not start at all when you w
Try to clean your coin filter trap underneath and then sanitize the unit before your next wash with bleach water and clean it.
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Aug 09, 2012 | Frigidaire Affinity ATF7000E Front Load...
Every time we wash there is water leaking, not sure were the water is coming from. i have checked the hose.
Hi.
Check that the leak is not coming from inlet valve itself. If the leak is from underneath the washer check drain pump hoses. You may need to disassemble the washer pulling up the top panel and accessing the drain pump at the bottom to find the leak.
Dec 05, 2010 | GE Profile WPRE6100G Top Load Washer
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
2,430 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
