Question about Zebra 105SL Thermal Label Printer
Blank labels keep feeding out
Hello and thank you for your product it has been very useful.
We have come to a problem though. On our computer blank labels appeared and someone pressed print anyways. Well, I deleted the print job through the computer, however every time we turn our Zebra 105sl, it keeps spitting out blank labels and won't stop and non of the bottoms on the machine are responding.
Can someone help us?
Thanks
Kate
Disable start up calibration maybe?
Posted on May 27, 2009
Prints lable every 5 labels the rest are blank
Troubleshoot to see if the problem is with the printer or the software. Turn the printer off and back on again for fresh start. After the POST (power on self test) press the FEED key and see if the printer feeds just 1 label. If it does then you know the optic sensor in the printer has a good read on label size. If it feeds more than one, then it needs to be recalibrated for label size.
If it feeds 1 label, then print a format. Now if it prints 1 label and then feeds blank labels, you know the problem is in the label software you're using or in the printer driver. The printer will only do what it's told to do.
At least this way you can narrow the problem down to the printer or the software.
Hope that helps....
Jun 19, 2011 | Zebra Stripe S600 Thermal Label Printer
Dymo prints blotchy labels and feeds out many labels after print
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Apr 30, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Label double print
It's possible that the printer did not get a good calibration on the size of the label. There's an optic sensor looking for the gaps in the labels. A test would be to turn the printer off and back on again. When it is ready, just press the feed key. If one label advances then the printer had a good read on the label size. The idea is to see if the printer works ok by itself first.
Now print a label - if you get two labels then you have to look at the software / printer driver as the cause. The printer will only do what it's told to do.
Hope that helps !
Apr 14, 2010 | Zebra LP 2844 Thermal Printer
Balster advantage label printer form feed
Hello David,
You have to make sure that the printer is not running out of ink.
Try to uninstall/re-install the printer driver. This often resolves the issue about printing problem.
Apr 16, 2009 | ATSI Holdings BD422003 Thermal Label...
Zebra LP 2844 spitting out blanks
Look at the stocks tab in the driver. There is an area in your print driver to adjust the width/height of the kind of label you are trying to use.
Apr 08, 2009 | Zebra LP 2844 Thermal Printer
MY TLP2844 SKIPPING LABELS HOW CAN I FIX IT
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
Roxio Label Creator won't print labels (blank with scissors)
Go to the label creator in your Roxio 6, Click on EDIT, then click on PREFERENCES, go to the DISC tab and unclick the "Print Disc cut Lines" and the "Print Disc outline" boxes. This should fix your problem.
Sep 13, 2008 | Roxio Easy CD & DVD Creator 6...
Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Sep 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Zebra 105SL Thermal Label Printer Logo
787 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
