My washing machine has started making a large clunking sound when washing which makes the belt come offand I can't work out how to get to the pump to see if this is the problem or if something is trap
The machine clunks when washing and the belt then comes off
  • 15,935 Answers
The only fix here is to be sure the belt tensioner is good.
Deflection should be about 1/4" on the longest run of the belt.
If it is adjustable - tighten it. If it is automatic - replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
My washing machine makes a cluck sound at the end
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Nov 07, 2009 | Washing Machines
GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
May 03, 2009 | GE Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Stopped spinning after making loud noise.
First check if the motor is lose, if ther touting is in place, if some bolt is lose, or if there is any broken part. You can see this at eyesight.
When washing machine vibrates in this way usually you need to replace thrust bearing, see this document and also this one here
If you insert right model number here you get exploded view and parts
Sep 02, 2008 | Maytag Performa PAV3200
Whirlpool washer repair
is the belt still attached at the back
Mar 03, 2008 | Washing Machines
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Noisy dryer
Don't turn the tub to much this may make the belt run off track . If the machine makes a rumble at the beginning and at the end or when u stop the machine and restart it it is probably the blower wheel,it is made of plastic ans wears out on the motor shaft.
Apr 05, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
