Audio cut out
My tascam MD-801R deck keeps cuting out mid track and once I saw a message which says 'Servo error'. Anyone have any ideas what the fault may relate to. Thanks David
  • 30 Answers
SOURCE: tascam midi and audio conflict error
First try turning off the onboard audio device using the BIOS interface. Try pressing f4, f2 or delete key rapidly at the flash screen beginning when you first turn on the computer. Look around in the bios (usually in "integrated periperals" area) and disable any onboard audio options that you see.
-In windows XP you can go to Control panel - Sound Devices and change the "map through" feature, select your default device, and run a hardware test simulation with a microphone for each device. Nice setup btw.
Posted on Feb 27, 2008
SOURCE: Tascam 238 tape deck
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Posted on Oct 12, 2008
dj_relly999
  • 4070 Answers
SOURCE: On the epson stylus SX405
Hi! Yes it can be but as a first course of action I strongly suggest that you unplug the unit from power source and press on for 15secs. to reset the scanner's system. After 15secs. please plug the unit to power source, turn the machine on and see how it goes. Hope this helps and thank you for using FixYa!
Posted on Nov 04, 2010
gregorygabri
  • 21 Answers
SOURCE: tascam md-350 "cannot copy" error
You do not need any cable for copy data it isn't that complex, you just need a right software which is Long Path Tool to copy anything anywhere.
Posted on Oct 02, 2015
skywavebe
  • 1258 Answers
The motors have long been out of availability and they need to be repaired now. I do them but some of them still have problems which have to be resolved. The new motors they sold would be no better that the ones in the deck as they were made with the same junk SMD parts
Posted on Jun 11, 2017
Tascam 238 recording deck will not stop rewinding.
Are you any good at surface mount circuit board repair? It seems that the caps go bad. Check out this: http://www.thegreatbear.net/audio-transfer/8-track-cassette-capstan-motor-tascam-238-syncaset/
Jun 08, 2014 | Tascam 2488 Portastudio Multitrack...
Tascam md-350 "cannot copy" error
Like all home recorders, yours will not let you digitally record digital originals. The Serial Copy Management System (SCMS) is designed to prevent piracy.
Unfortunately it also means you cannot copy your own digital originals digitally.
Record them via the analog input. It will sound fine.
Nov 06, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
Hi, I have a Tascam CD-A500 combo CDplayer/cassette recorder. The CD player has started skipping with very minimal vibration. This is new and never had these problems before. It is the most sensitive when...
Laser assembly is losing its ability to properly focus on the disk surface. It is going to La La land and needs to be replaced.
Get another player since repair is not cost effective.
Mar 19, 2017 | Tascam CD-A500 CD Player
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
Tascam 8 track recorder won't play back recording
Does it use MiniDiscs? If so, it cannot work with standard audio MiniDiscs, it requires a special DATA MD.
Jan 21, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Master Track too big to export.??
Im having exactly the same problem as you have/had..I cant Export the Master Track..It says "Too Big", have you been able to solve it?
Best Wishes
Steve
Mar 30, 2009 | Tascam DP01 All-In-One Recording Package...
Mar 21, 2008 | Tascam Audio Players & Recorders
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Tascam midi and audio conflict error
Feb 26, 2008 | Tascam US-144 Sound Card
80 people viewed this question
 Grubhead
Grubhead
