Question about Zenith ZHX-313 System
My Panasonic Omnivision VHS won't eject
A tape ha gotten stuck in it, it had just spinned and tangled in the vhs. I openned the vhs and got the tape out, but the vhs is still in the play position. And I can't get it to eject (with no tape) and with the tape back in it how it's supposed to be. I've tried everything I can do, but no luck.
If you can help with my problem, please email me at leira325@hotmail.com.
Thank You.
  • Anonymous Mar 17, 2014
    about 1/4 inch of tape cassette thickness is visible through the entry port flip-up door
Take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
Posted on May 09, 2009
My Panasonic VHS Player Model PV-V4020 is locked up so I cannot insert a new tape.
This will be some form of physical damage to the carriage mechanism, that holds the tape. Sometimes it's a simple thing like the flap getting stuck. But often it's a broken piece of plastic.
Apr 21, 2013 | Televison & Video
Tip
How to eject a stuck vhs tape.
I will show you how to eject a stuck vhs tape. I did this on the sony slv-d300p first, unplug it. Next, take out all the screws on the back. Take off the cover. Locate the loading motor on the right. Turn the gears next to it. After about 5 minutes, the tape should eject. While its open, take a CLEAN piece of paper, hold it up to the drum, and rotate it with the paper against the back. after 5 minutes, take the paper off and stop spinning. the paper may be dirty. put the cover back on, and try to put in a vhs c adapter with NO vhs c in it. when you put it in, it should spit it back out.
on Jul 15, 2010 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Jun 01, 2010 | Televison & Video
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Nov 22, 2009 | Panasonic PV-C1332W 13 in. TV/VCR Combo
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
The cassette is stuck...
the tape is trapped in the mechanisms, you have to strip the VCR down to get the tape out
regards
Nov 26, 2008 | Panasonic PV-7400 VHS VCR
Zenith ZHX-313 System Logo
249 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
