Question about Onkyo TX-DS696 Receiver
Zone 2 Speakers
My zone 2 speaker jacks on my 696 have gone dead, they were previously working fine but have no output now. I have triple checked the wiring to my speakers and it is fine.
I think I might have inadvertantly moved the speaker impedance switch while the unit was turned on, would this kill the outputs? If so is there a fix?
    New Friend:
    Problem Solver:
  • 11 Answers
YES
Posted on Nov 28, 2017
5 Suggested Answers
SOURCE:
  • 151 Answers
SOURCE: I have a TX SR
Try to reset your amp then go to the bottom of the set up menu and you should find lock set up,if this dose not work its repair time for your amp.
hope this helps.
CABLE GUY.
Posted on Jul 12, 2008
chrisreitano
  • 85 Answers
SOURCE: onkyo tx-sr601 bi wire with zone 2
SMCCARTY,
The idea behind bi-wiring speakers is to get the highest quality of sound by getting the sound from two separate sources doing separate jobs. Lower frequencies are harder for an amplifier to produce than higher frequencies. So it is common to give these frequencies to two different amplifiers so each can produce the highest quality of sound. By removing the low end from the top end amplifier, it provides the top end amp more headroom thus reducing the chances of clipping. Clipping can easily be heard from the tweeters destoying not only the sound but your speakers as well. It is common practice in pro and car audio to use separate amps for subbass, low, mid and high; four amps working together to their corresponding drivers (more or less depending on the system and type of audio being produced).
In your case, getting the two different sources from basically the same amp (power supply), would not accomplish the full intent of bi-wiring; it would just make more wiring for the same end result. However still a good thought on your end. Onkyo receivers are great because of their beefy power supplies. Not very many other brands have such strong power supplies. Denon's are close but not equal.
Chris-
Posted on Feb 15, 2010
Testimonial: "Thanks that saved me time and money "
dunnbiker
  • 8546 Answers
SOURCE: Zone 2 audio output is for analog only? The only
Speaker outputs at this state of the technology are always analog.
The iPod would use an INPUT like any other audio device. Once it's attached you can do whatever you want with its audio.
Your Zone 2 can be configured to play just about any input.
Posted on Apr 28, 2010
smarthome2
  • 1114 Answers
SOURCE: Zone 2 doesn't work. on set-up zone 2 is active.
Disconnect the speaker wires at the receiver for zone 2 then test zone 2 on again. If it stays on, disconnect the wires at the zone 2 speakers, make sure wires are separated then reconnect at the receiver and test again. If it still stays on, Your receiver is good, your wires are good, you need to connect one speaker at a time and test power again. When it shorts, pull the speaker and meter it for a short. If your not sure how to do this, take it to any local audio shop and they will usually test for free.
If you have a volume control on zone 2 speakers independent of the receiver, you need to pull it and check it as well for corrosion or shorts.
If at the first step, your receiver still shuts off, the problem is internal and will need to be serviced. If you need further help on this, post a reply or comment and I can help you further. Hope this does the trick!
Posted on Jul 06, 2010
Is there anyway to get an amplified signal to my zone two speakers without an additional amplifier? Should I be using the Speaker "B" outputs?
Check your speaker setup menu to make sure that zone 2 is enabled. Also, a lot of receivers only allow analog inputs to be used for zone 2, so if you are using something like hdmi, or optical than this might be the problem.
Jul 27, 2016 | NAD T754 Receiver
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
Yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Feb 22, 2009 | Yamaha RX-V1800
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Itunes assigned to CD stereo outputs to zone 1 but not zone 2
Ron Digital audio will only reproduce in the surround area you will have to connect using analog connections in order to get that sound in the 2nd zone
Dec 14, 2008 | Denon AVR-2807 Receiver
Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Jun 22, 2008 | Denon AVR-1907 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-DS696 Receiver Logo
64 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
