Cant locate it on computer
My 1 tera byte hard drive dosent show on my computer.i.e the control pannel it worked yesterday all i get is the blue light and am unable to find it on my computer.however can see it when i safley remove hardware
  • derekkjohnso May 11, 2010
    Has it been partitioned?
    Champion:
  • 381 Answers
Hi...ok lets try this..go and click the Control Panel then find and click the Administrative Tools then (double Click) find Computer Management(double click) and find the Disk Management then (once) then find what HDDrive you need..Thanks and GOD Bless..^_^
Posted on May 09, 2009
    Genius:
  • 1,550 Answers
Check the cable who connects with the mainboard sometimes get a litle loose
Hi my friend: please help me for select HDD. 945GCM-S2L Max HDD Support? 945GCM-S2L <- this mainboard supported 2TR Byte?
This motherboard suports SATA (Serial ATA 3Gbps) meaning that it is compatible with any SATA hard drive. A 2TB (Tera Byte) hard drive is the highest capacity available on the market. This motherboard has 4 SATA connections so you can put up to 4 SATA hard drives into it.
Mar 15, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
I have the WD tera byte hard drive and I plugged it in after many months and it will not show that it is working?? Also, a lock is showing up above the one bright light on the hard drive...any advice?
It could be a few things, some of them caused by hardware (the gear and computer and this "my book" backup device) and some by the software you are accessing it (the Operating System, etc).
What makes it tricky is that you probably have data on this you don't want to loose. It might be too late for that, without serious trouble shooting, so the order of the steps we use to troubleshoot and fix it could be important.
I'll need to know your
1) OS (widows XP? Vista? Ubuntu???)
2) What you did when you plugged it in as well as
3) what happened last time you shut it off/unplugged it
4) what you're currently doing or have tried.
5) how precious the data is on the "My book"
6) and do you have access to another computer?
7) did you change anything on the "My book"?
If the system is on, don't turn it off or unplug it yet.
Sep 05, 2010 | Western Digital My Book Home Edition 500...
My memeory card is showing please inset disk
if the light is working correctly then the usb is ok.
go to controle pannel, administrative tools, device managment, and select disk managment, locate your usb drive, right click on it, and format.........
May 06, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Will Asus p5ld2-vm SE MOTHERBOARD support 1 tera-byte hard disk? i hav 2gb ram
Yes it should. The issue is not so much with the motherboard supporting the hard drive. It is more the question of whether or not the power supply will support the power required to run it along with all of the other additions.
Jan 03, 2010 | ASUS P5LD2-VM Motherboard
Wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Jun 09, 2009 | Western Digital 500GB My Book World...
Iomega 500 GB hard drive has stopped working
new power adapter. Had same problem with a my book. I have two of them, and one is a tera other a 500gig. when I switched cords they both worked fine.
May 27, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
How to recover WD passport250 Data
hi...if you want to see again the files on the external hard drive i suggest you make to re-install the windows or repairs the windows you`re using or try to update the mother board drivers..thank you...^_^
May 09, 2009 | Computers & Internet
I bought 2 gb transcend pen drive yesterday. When opened n checked it shows 1.88 gb available memory. Why less than 2 gb? is my question.
this is because of the why bits and bytes are stored. 1 gigabyte is 1,073,741,824 bytes in reality. so 1.88Gb 2,018,634,629 bytes whcih for advertising purposes is 2 gigabytes. So you will generally always see this disparity because computers read bytes where 1 kb = 1024 bytes, and advertisers use 1kb = 1000 bytes. But don't worry you really did get 2 billion bytes it's just a little marketing sleight of hand :)
Jan 09, 2009 | Computers & Internet
Rams
1GB is 1000MB
Starting from scrap:
1 bit = 0/1 value, this is the real unity
1 Byte = 8 bits (eg : 010110100101 )
1KB=1000 Bytes
1MB=1000KB
1GB=1000MB
1TB=1000GB (TB is tera byte).
Oct 25, 2008 | Computers & Internet
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
