Screen showing sorter not ready. we have no manual
We have a toshiba 3550. We bought it seconfd hand and are now trying to set it up. It starts up fine and the feed tray moves into position butwhen it is the screen says " sorter not ready". I don't have a manual. It a church machine.
    President:
  • 1,126 Answers
If it has a sorter, then there are 2 AC power cords that need to be plugged in. One for the copier and a seperate one for the sorter. Can you describe the sorter to me, please...does it hang from the left side of copier? Does it set on the floor and roll up to copier? I can think of 4 different models available for Toshiba 3550 copier.
Posted on Jun 16, 2009
I have a Toshiba 3550 w/ malfunctioning mg-1003 10 bin sorter. I would like to disable the sorter and run without it. I was told to change system mode 4 from 1 or 2 to 0. It was already set to 0. Which...
Please check out these codes and descriptions, if they are ever helpful.
C01 Main motor drive problem C21 Optics problem Scan , lens, mirror C26 Exposure lamp detect problem C32 Setup error (UA) C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem C54 Communication problem between sorter and machine main board C55 Communication problem between ADF and machine main board C71 ADF drive problem C72 ADF registration sensor problem C73 EEPROM initialization problem C81 Sorter paper conveying motor C82 Sorter bin motor C83 Sorter upper sensor C84 Sorter lower sensor C85 Sorter home sensor C86 Sorter copy removal sensor C94 Optics initialization problem in test modes E01 Paper jam E02 Fuser jam E03 Paper jam E05 Paper feed jam E14 lower cassette jam E71, E72, E73 ADF jam E75 ADF jam of 2nd original E81, E82 Sorter jam
Good luck.
May 23, 2010 | Office Equipment & Supplies
Console interface problem on the switch
HyperTerminal sucks. Use PuTTY and make sure you have the correct baud rate of 9600 set.
Putty Link:
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Mar 30, 2010 | Cisco Catalyst 3550-24 24-Port Ethernet...
Minolta Copier's sorter bin won't close properly.
This 20 bin sorter uses an interlock switch and actuator to show that the sorter is properly attached to the machine. Pull the sorter away from the machine and look at the rear side of the copier that faces the sorter. There should be what looks like a spike mounted to the copier. That spike goes into a hole in the sorter which then actuals the switch. Make sure the spike is not broken or loose. Make sure the tray that the sorter sits on is not bent. Correct any issues with these 2 and you should be good to go.
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
Jun 01, 2009 | HP DeskJet 3550 InkJet Printer
Toshiba;Can't make a copy
C54, lost communication with the sorter, Check the sorter/ finisher, make sure the connections are firmly seated, even try unplugging the sorter from the machine and replug it in.(Power Off first).
Restart machine
Hope this is of some help.
Ed
May 19, 2009 | Toshiba e-Studio 350 Copier
Need help disabling Toshiba 3550 sorter
I don't have operational sorter, but I can locate one for you if you are interested. Now, the solution to you copier is for you to go into the service mode and change the setting from sort to non-sort. This is the step you need to take. Go to the Service mode by doing the following.
1. Turn of copier
2. Push on 08 then Power on copier
3. enter 4 then
4. Push Print
5. Change the current value from 1or 2 to become 0
6. Push or press Interupt to reprogram the copier.
7. Then enter 09 to get out of the service mode.
Good luck.
Mar 23, 2009 | Toshiba Office Equipment & Supplies
CanonIR 5570 Copier reboots then jams at sorter
Sounds like the sorter connection between the two is poor or disconnecting, check the cable from sorter and power lead to the sorter are secure.
Check switch that machine uses to know when sorter is engaged is closing proberly/not bent
Check sorter indicator lights (if any) after reboot,
Try running lead to it from elsewhere in case there is too much drain or something weird with power supply where you are
Jan 12, 2008 | Office Equipment & Supplies
Document sorter for Toshiba 3550
Do you have sorter ?
İf not you should reset the machine
Jan 10, 2008 | Office Equipment & Supplies
Toshiba 3550 Document Feeder
1- you've already established that the jamming is coming from the sorter, since you said they jam as they exit the copier into the sorter bin.
2- check to see if the sorter is aligned, is one side higher than the other? is it crooked? are the wheels of the sorter turning as the paper exits the copier, is it plugged into the copier? does it show "connect sorter" when detached from copier?
if not the sorter board may be bad.It may need to be aligned ( not easy if not used to doing.)
Nov 25, 2007 | Office Equipment & Supplies
k24674
jasbo
jasbo
