Question about Microsoft Windows XP Professional SP2
Services.msc hi in srvices.msc server and workstation service stoped automaticaly,then start the service after rebooting service stopped what is the issue ?
  • 413 Answers
Also, try by applying the patch WindowsXP-KB958644-x86-ENU, this has resolved the problem.
Posted on May 09, 2009
Error0x00000015
This is how you have to do it. You need to enable WIA - Windows Image Acquisition. now to do that follow these steps.
1. Click on start or the Window thingy.
2. Type Services or Services.msc in the search part.
3. Now scroll to the following services in the window that got opened.
Remote Procedure Call (RPC)
DCOM Server Process Launcher
RPC Endpoint Mapper
Shell Hardware Detection
Enable those services. To do so right click on them, click properties and make it automatic. Once you enable all of them start them. After all the services are started scroll for "Windows Image Acquisition" make this automatic too and start it. Just reboot your PC and you should be good to roll
Apr 03, 2014 | HP PhotoSmart Office Equipment & Supplies
0x00000015 epson cx9300f
Assuming you are using Windows 7 as operating system.
1. Windows button + R
2. Type Services.msc and press enter
3. Now find the following services
RPC Endpoint Mapper
To enable those services.
Right click on them, click properties and choose automatic ( will start automatically). After all the services are started and marked for automatic start, find "Windows Image Acquisition" and make this automatic too.
Reboot your computer.
Oct 08, 2013 | Epson Stylus CX9300F Series
I am trying to reinstal lexmark software but i got code spooler service is stoped
Here's how to restart the spooler:
  1. Click Start.
  2. Type services.msc in the Start Search box. NOTE: Windows XP users will select Run.
  3. Click services.msc in the Programs list. NOTE: If you are prompted for an administrator password or for confirmation, you can either type your password or click Continue.
  4. Locate and right-click on Print Spooler, and then click Stop from the drop-down menu.
  5. Right-click Print Spooler again, and then click Start from the drop down menu.
You may also refer this link: How to Restart or Reset the Print Spooler in Windows
Apr 04, 2011 | Lexmark X75 All-In-One InkJet Printer
Lan connection
this error comes when the network service is stopped .you can fix this serror .just type services.msc in run window and go to service local .in that you will see computer browser option just double click on it and make the setting automatic startup and start the service if it is stop and alos in workstation service alos do the same thing make the setting automatic startup and start the service if it is stop.
hope this information will help you dont forget to rate please. have a nice day.
Feb 24, 2010 | Computers & Internet
Distorted pvr picture
Which SageTV version are you using.. Make sure you disable the two services for Hauppauge in the services.msc. You can't have both running. If you use SageTV with MediaMVP.
Click on Start for XP or Orb for Vista
Click on Run
Type: services.msc
Scroll down for MVP two services and make sure they're not started or enabled.
Reboot the PC also.. Make sure you have SageTV MVP Client Licenses to run your MediaMVP. There is a license needed for each MVP client you have. Thanks, __________________
Dec 09, 2009 | Computers & Internet
Print Spooler Service is not running error message
You need to start/enable the print spooler service.
Goto Start > Run and type "msconfig" then hit enter
Under the General tab, check "Normal Startup - load all device drivers and services",
click "apply" and reboot.
If you still get the error
Start > Run", typing in "services.msc", then hit enter
scroll down to print spooller and make sure it's enable "started" and runs automaticaly
Mar 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer Spooler service!
This will provide you with the most common default settings.
  1. Restart (reboot) your system [to assure a clean reinitialized starting point].
  2. Log on as any Windows user that has 'administrator' privileges.
  3. Open your 'Services' console [Start button > Run... > type "services.msc" (without quotes), then hit 'Enter'].
  4. Locate, then open "Print Spooler" [double-click it OR right-click it, then choose "Properties" from the context menu].
  5. Modify the settings on the "General", "Log On", and "Recovery" tabs according to the following images.
"Today's the best day of my life...and NOW you're part of it!"
Dec 11, 2008 | Lexmark E120 Laser Printer
Can't uninstall nero 7 premium on windows 2003 server
Download and install this:
Description of the Windows Installer CleanUp Utility
Run it and select anything Nero and remove it.
Go to Start>Run>Services.msc and stop any services that belong to Nero. Set the startup type to Disabled.
Reboot.
Delete the Nero folders in Program Files.
Go into the registry and check for Nero and/or Ahead entries and delete them. I suspect you'll find some in the Run or Runex keys as well as under Services.
Reboot.
You should be good to go.
If you're timid about the Registry then backup the keys you are deleting by right-selecting the parent key and going to Export. Save the key to a reg file.
Feb 11, 2008 | Microsoft Windows Server Standard 2003 for...
"The RPC server is unavailable"
I?m assuming this is happening on a Windows machine. This is one of the really vague error messages that Microsoft give for an incredibly large number of problems. I typically see this on servers but have seen it occur on workstations. If you?re running XP, 2000 (server or Pro), or 2003: - Check and make sure your Remote Procedure Call Service is running. - There is an older vulnerability that tries to use a flaw in the RPC services. It is fixed if you copy of Windows is up to date so make sure it is. - Review your application log for any clues. If you need more assistance let us know your operating system, if it is fully patched and what is showing in your log file around the time you receive the error message.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
Microsoft Windows XP Professional SP2 Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
