Question about Ricoh Office Equipment & Supplies
The axe of one gear for a richo scanner is broken
  • 183 Answers
That is happening on lot of new ricoh machines you should order the drive shaft and a hexagonal screws for to be replaced
Posted on Jul 12, 2009
I have an old Richo 35mm SLR purchased in 1968. When you advance the film and release the winding lever it fires the shutter. Can i do a DIY repair.
Doubtful. The inside workings of older film SLRs are like watches, lots of gears and such. If something has broken, which this sounds like, then you'll need replacement parts and a source for them. You might try checking this website for more info:
Ricoh SRL Systems manuals instruction
Dec 16, 2014 | Photography
Why cv axle is twisting
Are you trying to tell us that when you put it in gear.. the axel spins and moves up and down because of a broken CV JOINT? In this case the axels are sold rebuilt for really low price. Rockauto.com. They are not real easy to change.. look under the car while someone puts it in gear.. WITH THE E BRAKE ON AND WHEELS BLOCKED.. AND SEE WHAT THE AXE; IS DOING. Then you can make an assessment of what to replace.
Aug 22, 2014 | Cars & Trucks
My gear is slamming roughly when moveing from first gear to second gear
General advice:Draging clutch (dirty,worn),no oil in the clutch pump (need two three pedals...).Worn gearshifting lever link to gearbox (leading to missplace shift position)Worn sincro (gear brake engage ring) in the gear box.Worn gear/gear axe (tilting gear on the axe.in the earbox..box...)
Oct 26, 2013 | Dodge Ram 2500 Cars & Trucks
How to I keep my axe from accidentally scraping me?
You can buy an axe protector, which is usually made out of strong rubber or plastic.
Feb 04, 2013 | Rock & Ice Climbing
What is the purpose of splitting axes?
Splitting axe is used in wood splitting to split the grain of the wood. Splitting axe bits are more wedged shaped.
Feb 03, 2013 | Garden
Hook Drive Gear, Riccar #53741 how to take part off of sewing machine
Today I got such a machine (Riccar) for free from a lady I know. the only problem was that the needle walked against the bobbin (timing problem).
I screwed the sewingmachine open and after some screwing I saw that the part, Hook Drive Gear, Riccar #53741, was broken. Wat I did is I enscrewed two screws wich hold the part on the axe and with a bigger flat screwdriver I could just push the part from the axe, from the other gear. It looks more difficault then it is.
Now I have to get a new part, put it back and time the the machine so that the needle will go normal, at the right time, in the bobbin. Does anybody know the trick to do that?
regards,
Daan
Apr 23, 2012 | Riccar Sewing Machines
How to clear error code E000051-0000 in canon IR3300 copier
To reset the error
1. additional functions (push)
2. function (choice)
3. error (choice)
4. error code choice (wait)
5. reset (push)
6. right power supply off
7. right power supply on
Apr 16, 2012 | Canon Office Equipment & Supplies
My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. Printers has a good connection to PC, start to print but after the first paper pass the...
I've just had this same problem with my Sephy 740. Nothing helped until I disassembled the printer and realizing the small gear wheel (not visualized) at position in the red circle had loosened. Remounting the gear wheel on the shaft with a tiny drop of Blue Loctite and letting dry three hours, reassembling the printer and turning it on fixed the problem.
Aug 06, 2011 | Canon SELPHY CP740 InkJet Photo Printer
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
Richo color scanner is760d don't have option auto feeder
This scanner can be controlled by PixEdit so you may scan any amount of sheets. Even easy continue scanning to one document when not enough space in the ADF for the hold stack
Dec 08, 2008 | Ricoh IS760D Flatbed Scanner
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
