Question about NAD C370 2-Channel Amplifier
Output on one speaker goes on and off
My Nad C370 sometimes drops out on one of the speakers. It can then come back on again after a while. It happens on both A+B speakers. I have tried turning the speakers around (left into right) (right into left) but it is still the same? Happens with all inputs Any help would be appeciated, Otherwise information on someone around the Blackburn area who could fix it?
  • 4234 Answers
SOURCE: Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Posted on Nov 05, 2008
Grubhead
  • 5444 Answers
SOURCE: NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Posted on Feb 16, 2009
smarthome2
  • 1114 Answers
SOURCE: NAD 302 PHONO STAGE
Reverse your RCA input around and see if the problem follows, this will determine if the problem is in the turntable output signal or the preampsection of your amp. If it stays on the same channel, slightly move the RCA that's dropping out signal around. If the signal cuts in and out, you know it's just a weak solder joint on the input rca of the amp. If it does not change, your problem is deeper. Chances are it's a "cold solder joint" on the input section of the amp and would only be a labor type repair and no parts involved. That can be a double edged sword as well depending on how long it takes to find it. If you have to have it serviced, find a local shop that's been around a while, they are likely to be a little more insightful as to the exact problem quicker. Hope this helps
Posted on Jun 26, 2009
Ganx
  • 113 Answers
SOURCE: nad c372 problem with left speaker output
Hiya, did you try to swop the inputs as well and see if the problem swops. Try that as the input could also be low. If so try change the cable.
If not there try cleaning out the balance pot with switch cleaner (have to open to that and only you are comfortable).
If thats not there then likely an internal problem and will have to send it in.
Best of luck
Posted on Jul 14, 2009
  • 7 Answers
SOURCE: myc370amp turns its self about 15seconds after turn on
Replace 3 capacitors on the protect printboard. (located near the outpt terminals) 50V electrolyt: 4,7uF, 47uf and 10uF. And move the big diode to the back of the printboard (the heat from the diode dries out the capacitors)
Work in 9/10 times ;)
Posted on Aug 17, 2009
Low base in one channel
The problem is most likely in your speaker. I have repaired hundreds of amplifiers and have never seen this problem in newer amps. Try swapping the speakers and see if the problem moves. This will prove that the speaker has a problem.
If it is an older amp, the problem may be the coupling capacitor between the amplifier output and the speaker terminal. These do go bad, and as the capacitance drops, there is a loss of the low end. I have seen this a few times, but it is not a very common problem.
My bet is the speaker is defective.
May 09, 2014 | NAD C370 2-Channel Amplifier
NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Mar 10, 2008 | Audio Players & Recorders
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
How to hock up two 8 ohms speakers to bridged 90 watt Nad 209Amp?
Depends on output requirement (in ohms) on the amp. Any further questions, don't hesitate to ask. If this is helpful, please post as such. TY
Jan 24, 2009 | NAD C370 2-Channel Amplifier
Nad C370
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Sep 15, 2008 | NAD C370 2-Channel Amplifier
Nad c370 problem....
Hi arda5
Did you try swapping speaker connections left for right on the back of the amp to isolate the problem. If the fault stays with the speaker, then that is where your problem is. Try this and get back to me here with the results.
regards
robotek
Jun 13, 2008 | NAD C370 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
530 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
