Question about HP OfficeJet J4580 All-In-One Laser Printer
Fax pick=up How do I set the number of rings before the fax picks up. I have distinctive ring and voice mail. Thanks
Use the spannern and arrow keys to navigate to Fax settings, and hit OK, then navigate to Answer Options, OK and down into Rings to Answer
Posted on May 18, 2009
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have a canon mx410 all in one inkjet printer.i need assistance with setting up the fax to a phone line. Thank you Zainy
  • Call your phone company to sign up for service. Ask for an additional line with a "distinctive ring." The additional line is for your fax machine---whenever you hear the distinctive ring you'll know that a fax is coming through. Get voice mail service on the regular phone line as well.
    Purchase a two-jack phone splitter (sometimes called a wall jack adapter) that allows two cords to plug into the same phone line. Plug it into the phone jack in your wall.
  • Run a phone cord from both machines into the wall adapter. Test the system by calling both your regular phone number (assure it rings and the voice mail picks up) and your fax number to see if the fax machine picks up (you'll hear a set of strange beeping tones).
  • Apr 13, 2011 | Canon Pixma MX410 All-In-One Printer
    Can't send or receive faxes
    it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
    Contact your phone service provider to see if they support faxes.
    (Faxes cannot handle nearly as much compression as standard voice)
    Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
    I am trying to setup answering data and fax on the same phone line. What setting do you use to isolate data vs voice for incoming calls and either the fax pick up or the phone call go to a voicemail? JC
    Order "distinctive ring" from your telephone-company.
    One style of "ring" can be routed to the FAX,
    and the other style of "ring" can be routed to voice-mail.
    Nov 01, 2009 | HP Office Equipment & Supplies
    Canon image class MF4150 distinctive ring
    How to Set the Receive Mode (MF4140/MF4150)
    1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
    Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
    Same fax and phone number
    check the setting in the receive mode button. set it to fax
    Mar 29, 2008 | Canon FAX-JX200
    Setting personalized ring
    Its called distintive Ring. This is the instructions from the manual -
    VERY IMPORTANT
    If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
    one of your phone numbers dedicated only to fax calls, you must leave the fax machine
    in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
    Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
    machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
    distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
    mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
    answer calls for all the numbers.
    Registering the Distinctive Ring Pattern
    Set the fax machine to MANUAL mode.
    2 Press Menu/Set, 0, 1.
    3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
    4 Press to select the prestored ring pattern you want to assign, and then press
    Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
    Be sure to choose the pattern assigned by the Telephone Company.
    5 Press Stop/Exit.
    and a link to the manual if you need it -
    http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
    Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
    HP OfficeJet J4580 All-In-One Laser Printer Logo
    88 people viewed this question
    Seeker5211
    Seeker5211
