Question about Indesit W 123 Front Load Washer
Lights flashing on indesit WIL123S
I have an indesit WIL123 that is flashing the door lock led rapidly and the delay timer and easy iron lights as well when you first switch it on it seems to be going through its start procedure then after about 2 mins it stops and the lights start the book says i need to get assistance have you guys any ideas thanks
    Sergeant:
  • 197 Answers
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
Posted on May 09, 2009
Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Aug 12, 2007 | Indesit W 123 Front Load Washer
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
The On-Off door lock LED flashes rapidly at the same time with Delay, Timer and Rapid LED. and it wont start.
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
May 04, 2011 | Ariston Technologies AW129NA 16 Lbs Front...
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
2,091 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
